Old 03-30-2009, 10:31 AM
bman356 is on a distinguished road
Radius with c-axis?
I am using a Daewoo Puma 240M with a fanuc 21-1 control. Using a 3/16 endmill and live tooling I am doing some machining on the O.D of a part. Linear moves are no problem, Z programs normally and the chuck (C-axis) is programed in degrees. What I want to do is make a radius between the Z and C-axis. I am not sure how to do this other than programming many straight moves every .003" to produce a fairly "round" path. Is it possible to program a g02 or g03 and if so how do you program it. Thanks in advance.
Brad
Old 03-30-2009, 10:31 PM
dcoupar's Avatar
I believe your control has the cylindrical interpolation option enabled. That should work for you. See attached.
Old 03-31-2009, 07:36 AM
That is exactly what I was looking for. Thank you!!
Brad
"Radius to end of arc differs from radius to start on Line #" labuda G-Code Programing 8 11-15-2009 06:35 AM
Need Help!- Outside radius Shibumi G-Code Programing 1 10-30-2008 10:27 AM
Fanuc 5 axis radius compensation d.a.v.e Fanuc 1 10-06-2008 02:52 AM
Radius in z axis? pp-TG G-Code Programing 4 01-24-2007 05:18 PM
Zero Radius Arc Xular Mach Mill 4 12-13-2006 09:10 PM
