Old 01-06-2005, 10:17 PM
capitalv is on a distinguished road
I Need Help G Coding A Bolt Circle
I am using Master 5 on my cnc router. I want to drill a 40 hole bolt circle on a 7.5" radius. Master 5 does not recognize g72, so how would I write the gcode for this operation.
Old 01-07-2005, 10:56 AM
HuFlungDung's Avatar
Moderator
Draw it up in a cad, if you have one, and write down the point locations. Or calculate them with trig.
Does your controller use a G81 or G83 drill cycle? Use those with the list of coordinates is typically all that is required.
Old 01-08-2005, 12:07 AM
gmfoster is on a distinguished road
There are some programs to generate gcode for specific jobs here. I didn't check to see if the one for bolt holes would go to 41 or what ever you are needing.
http://pico-systems.com/gcode.html
Garry
Old 01-08-2005, 12:34 AM
Gold Member
JFettig is on a distinguished road
I always do what huflungdung does or says to do, just draw it up in cad and take my dimentions off the readout thing or something similar.
There is a partially decent free cad program out there that is pretty much an autocad clone, its called a9cad by a9tech.
http://www.a9tech.com/download/
Jon
Old 01-08-2005, 01:05 PM
Moderator
Jon
Hey, my first disciple! Welcome, my son.
Old 02-03-2005, 03:01 PM
bbailey is on a distinguished road
I wrote a program for the Palm pilot that automatically generates up to 50 boltholes. It also does alot of nice CNC programming features. If interested, let me know.
Old 02-03-2005, 03:11 PM
Swede's Avatar
Swede is on a distinguished road
I also programmed (YEARS ago) a super-bare-bones bolt hole calculator, for Windows, that is extremely simple but effective for doing the X,Y coordinate list for bolt circles. It allows one to offset (from 12:00) the starting hole, so the first hole can be at 10 degrees from 12:00, etc. PM me if interested.
Old 02-03-2005, 06:04 PM
*Registered*
ESjaavik is on a distinguished road
Originally Posted by bbailey
I'm interested , especially if it can run on my old Palm III, as I don't want to take my new Palm in the wshop.
Can it beam the result to a Linux PC? That would be super as I would not have to punch it into the editor by (greasy) hands.
Old 02-04-2005, 05:09 AM
Send me your e-mail address to my private message, and I'll send you a copy.
Old 02-04-2005, 03:40 PM
mike_lera is on a distinguished road
Capitalv give me your e-mail and i will send you the code for a 40 hole 7.5" .5" deep ready to run
  #11   Ban this user!
Old 02-19-2005, 11:34 AM
oldjohn's Avatar
oldjohn is on a distinguished road
Smile
G'day
See if you can use this macro. you can use it for any hole circle, just chance variable values and edit start and end of program to comply with your machine control.
O2020 (SAMPLE BOLT CIRCLE B-MACRO)
(MITSUI SEIKI HS3A - FANUC 15M)
#10=8 (NUMBER OF HOLES )
#11=0 (ANGLE OF FIRST HOLE )
#12=80. (BOLT CIRCLE DIAMETER )
#13=0.0 (-X- CENTER OF BOLT CIRCLE )
#14=0.0 (-Y- CENTER OF BOLT CIRCLE )
#15=5.0 (-R- PLANE )
#16=-20.0 (-Z- DEPTH )
#17=150.0 (FEED RATE )
(DO SOME SETUP CALCULATIONS)
#12=#12/2 (BOLT CIRCLE RADIUS)
#20=[360/#10] ( ANGLE BETWEEN HOLES)
#10=#10-1
G0 G28 G91 X0 Y0 Z0
M1
N2 T2
G30 G91 X0 Y0 Z0
G58 G90 X0 Y0 Z0 B0
M10
S2000 M3
G43 H2 Z50. M8
Z10.
(FIRST LOCATION)
G81 X[[COS[#11]*#12]+#13] Y[[SIN[#11]*#12]+#14] R#15 Z#16 F#17 (DRILL CYCLE)
WHILE[#10GT0]DO1 (LOOP)
#11=#11+#20 (POSITION HOLE TO DRILL)
#10=#10-1 (NUMBER OF HOLE DECRIMENT)
#21=[[COS[#11]*#12]+#13]
#22=[[SIN[#11]*#12]+#14]
X #21 Y#22
END1
G80
G0 Z50.
T0
M11 M9
G91 G28 Z0M5
M1
G30 G91 X0 Y0 Z0
M6
G28 G91 X0 Y0 Z0
M30
Old 02-19-2005, 01:55 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
has anyone setup a g-code to cut a hole patern on the actual deckin of the router, to be able to place clamps to hold your material down... similar to holes for a vacume table.
Milling a Circle rcazwillis General Metalwork Discussion 15 04-19-2005 09:21 AM
Supplier of Plastic Hex Bolt Covers - Where? creative_mind CNCzone Club House 3 12-30-2004 10:23 AM
Bolt spacing on THK rail? samualt DIY-CNC Router Table Machines 6 07-24-2004 07:36 PM
Bolt On Quill Drive Unit Kookaburra Bridgeport and Hardinge Mills 11 04-01-2004 12:19 AM
Find the center of a circle Hobbiest WoodWorking 7 01-28-2004 12:24 AM
