| G-Code Programing Discuss G-code programing and problems here! |
hello, got our first mill, im a lathe guy, and i am trying to learn some basic programming. I have a part that is out of .3125" wide x 1.0" tall stock and i have to mill the end of it and put .05" x 45 degree chamfers on each side on the entire 1 inch depth. i am hanging out of the right side of the vise. i am going to call the edge x 0. also. i am using a 3/8" endmill. and if it is easy to explain can you walk me thru figuring out the start and endpoints. ------\ ^ . .312 | ------/ v thanks phil Last edited by prupp; 03-24-2009 at 08:51 PM. |
| Hi prupp Yes a lot of people would know how to do this but it takes time Here is a txt file that you can run that will do the job Put the piece in the vice with .500 hanging out of the vice right hand side The Y0 is the back of the part the X0 is the end of the part Tool Z0 Tool at the top of part RUN in SINGLE BLOCK to TEST with the .375 End Mill everything should clear There are other ways to do this but this is what you wanted I also don't know how you want the 45deg this is .050 from the point in I can change it if you need to
__________________ Mactec54 Last edited by mactec54; 03-25-2009 at 01:07 PM. |
| This link should take you to a Programming Workbook in a pdf file on the Haas website: http://www.haascnc.com/training/Mill...m_PDF/xmwb.pdf
| Silly Question BUT What Unit is Feed in on a Haas Mill | JWB_Machining | Haas Mills | 7 | 10-15-2008 07:39 AM |
| Need Help!- HAAS MINI MILL Question (I'm pulling my hair out) | Powder_Keg | Haas Mills | 7 | 09-19-2008 09:09 AM |
| haas lathe programming question | pavelbure | Haas Lathes | 4 | 06-17-2007 10:17 AM |
| Haas mill multiple vise question (programming) | joesimmers | Haas Mills | 14 | 03-29-2007 05:48 AM |
| Haas Mini Mill Programming Question | CuttingTools | Haas Mills | 41 | 05-24-2006 08:44 AM |
