Old 03-20-2009, 07:07 PM
THend is on a distinguished road
4 axis g-code help
Ok, been running a 4 axis foam cutter for years using a canned software.
I've recently been running a nice 3D router with Mach3.
Now, I've purchased upgrade electronics for the 4 axis foam cutter and will have bipolar setup.
I want to run G-code now to cut wings. This means that the horizontal axis will have to run at different feedrates, and so will the vertical axis. I want to be able to block the foam with rapid moves etc... then slow everything down for the airfoil cut.
Where do I start? I've been playing with 3 axis g-code for a little while so I am a tad familiar with how it goes.
I need to control the feedrate of each axis independanlty and at the same time.
How? Help?
Old 03-20-2009, 08:29 PM
Eurisko is on a distinguished road
This could be a problem.
Let's suppose you're feeding in two axes simultaneously, and that each axis has its own feedrate. Let's also assume that the X axis is feeding twice as fast as the Y axis.
G90 G00 X0. Y0.
G01 X10.0 Y10.0
What should be one 45 degree line becomes TWO lines.
(0,0) to (10,5)
(10,5) to (10,10)
The X axis will reach its target twice as fast as the Y will.
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 03-25-2009, 02:42 PM
I have learned something....
I now understand how it works, I didn't before, so my question itself was stupid.
All axis arrive at their destinations at the same time. Then acquire next destination.
Love it when the lights come on.
Old 03-25-2009, 06:27 PM
Your question wasn't stupid at all.
You were 'thinking outside the box' and that's good!
You can change the feedrate anytime you want. Use a fast feedrate for blocking the foam, then slow the feed down for the arcs.
G90 G00 X0. Y0.
G01 X5.000 F75.0 (fast feed for linear move)
G03 X0. Y5.000 I-5.000 J0. F10.0 (slower feed for arc)
Need Help!- APT to G Code for 5 axis machining help engineerartist General CNC (Mill and Lathe) Control Software (NC) 8 09-24-2008 10:19 PM
G Code REQUEST -- 4, 5, 6 Axis High Seas G-Code Programing 6 08-02-2008 07:41 AM
G code help C-X axis slkret G-Code Programing 1 05-10-2008 08:53 AM
zero axis key code? drafterman Mach Software (ArtSoft software) 2 03-06-2008 08:18 AM
Z-Axis Arc G-Code? GTmike400 G-Code Programing 16 01-27-2006 11:15 AM
