| G-Code Programing Discuss G-code programing and problems here! |
| Hi, don't know if this is the correct part of forum for my question. But since it has something to do with variables i'll try here ![]() Anyway, im using a Yasnac MX3, trying to set the Rotary Angel Settings for G56, G57, G58, G59, G56J2, G57J2 and G58J2. I have looked in the manual the parameter numbers for these values and it works fine with G56, G57, G58, G59 but not with G56J2, G57J2 and G58J2. I get error 108 (MACRO ERROR (UNDEFIN #NO)) Undefined variable NO. Designated. This is the code i made Code: % O2000 (G57Y)#6535=#6529+7600 (G57Z)#6536=#6530+110 (G58Y)#6541=#6529-7600 (G58Z)#6542=#6530+110 (G59Y)#6547=#6529+3800 (G59Z)#6548=#6530+30 (G56J2Y)#6719=#6529-3800 (G56J2Z)#6720=#6530+30 (G57J2Y)#6725=#6529+11400 (G57J2Z)#6726=#6530+240 (G58J2Y)#6731=#6529-11400 (G58J2Z)#6732=#6530+240 (G57X)#6534=#6528 (G58X)#6540=#6528 (G59X)#6546=#6528 (G56J2X)#6718=#6528 (G57J2X)#6724=#6528 (G58J2X)#6730=#6528 % Any clues? |
| I don’t have any experience with your control. But some variables you cannot write to or read from. My guess is that you can read and write to the G56-G59 settings as I do in a lot of my programs but the G56J2 are off limits. What are these settings? If they are like the G56-G59 settings have you tried to see if they can be set via G10? Stevo |
| What the G56 J2 is? Im pretty bad with the technical english terms but it's just a bunch of more workshift offsets you can set. Machine has up to J5. Normal G56 is J1 and then you have J2, J3 and so on. In some programs we use up to 8 workshifts so then we need to set G56, G57, G58 in J2 and use that along with J1 workshifts. This is all the workshifts Yasnac MX3 has. It's a few more then the 7 workshifts the Fanuc machine im using have ![]() J1: G54, G55, G56, G57, G58, G59 J2: G54, G55, G56, G57, G58, G59 J3: G54, G55, G56, G57, G58, G59 J4: G54, G55, G56, G57, G58, G59 J5: G54, G55, G56, G57, G58, G59 Have not tried with G10, didn't even know about the G10 untill a co-worker told me about it earlier today. Will try and find some documentation on G10 and see if that will work. Thank you. |
| I believe the #6000 series are setting numbers, not system parameters. Try using the equivalent system variables: WCS SET# VAR# G54 X #6516 #2501 G54 Y #6517 #2601 G54 Z #6518 #2701 I think the attached chart is correct, but it's late. See page 67 of the Operator's manual. Last edited by dcoupar; 03-17-2009 at 01:46 AM. Reason: Wrong page # referenced |
| Need Help!- Matsuura Mc500v seq error/magazine error | mc500v | General Metal Working Machines | 10 | 01-08-2010 01:35 PM |
| Variable changes | TNorbut | Controller & Computer Solutions | 0 | 07-23-2008 07:16 AM |
| variable subscript out of range error | hideaway | G-Code Programing | 4 | 03-15-2008 12:57 PM |
| EMC2 variable pitch / variable diameter threading. | samco | General Metalwork Discussion | 0 | 03-09-2008 01:40 PM |
| IF variable = bla THEN do this ELSE do that ? | iMisspell | G-Code Programing | 21 | 07-30-2006 10:57 PM |
