| G-Code Programing Discuss G-code programing and problems here! |
I've never attempted a canned drilling cycle before and the big yellow book seems to be confusing me more than helping me. Can anyone give me a straight forward example of a G83 canned cycle for Fanuc control, from start to finish. I would really appreciate any help, thanks. |
Try the link below there are some very good post there that will help you http://www.cnczone.com/forums/showthread.php?t=73951 |
| Read this, it will help. G83 is the same for a Lathe or Mill. The only exception is that unless you have a Mill/Turn your only going to program X0.0 and a Z Depth for a 2 Axis Lathe. The Mill is a XY location and a Z Depth. G90 G0 X0 Y0 G83 Z-.5 R.1 Q.1 F12. X0 Y0 Location Z-.5 in depth R.1 is the return point after each peck Q.1 is the Peck amount F12. is the feed rate at 12 Inches Per Minute
| That means that you will be using this format G0G40G99M5 G28U0W0 N2(DRILL) T202M8 G97S700M3 G0X0Z.1 G83 Z-.5 R.1 Q.1 F.007 G80 G28U0W0 T200M9 M1 X0 Location center of stock Z-.5 in depth R.1 is the return point after each peck Q.1 is the Peck amount F.007 is the feed rate at .007 Inches Per Revolution On a lathe you can use either G99 (Inches per Rev) or G98 (Inches Per Minute) Be careful when switching between IPR and IPM. The wrong designation will surely cause problems.
| canned cycle for lathe with fanuc control | JPann | G-Code Programing | 6 | 09-27-2011 12:45 PM |
| Fanuc Canned Cycle MACROS | kuyohtay | Fanuc | 9 | 05-20-2008 03:40 PM |
| G90 (Canned turning cycle) Fanuc 21i-TB ? | Jdavis733 | G-Code Programing | 0 | 01-23-2008 08:18 PM |
| Canned Cycle G73 Om Control Fanuc(drill) | marrieche | Fanuc | 1 | 03-05-2007 04:51 PM |
| fanuc 15i problems with g81 canned drill cycle | KyDeano | Fanuc | 2 | 01-20-2006 01:39 PM |
