Old 03-10-2009, 11:44 AM
japco43 is on a distinguished road
Question G code F speed
How do I write G code to be able to slow down and speed up during and after a corner or radius. When My Enroute 3 generates the code it puts in one F speed, and the whole program runs at one speed. Help? J.P.
Old 03-10-2009, 12:21 PM
Tcooper571 is on a distinguished road
You should be able to use one feed to a certain point, then slow down for your corner, then wen done with corner speed back up again. Here is an example: G1Z-1.F.01; G2X1.5Z-1.25R.25F.002; G1Z-2.F.01;
Not sure if this is what you are refering to.
Old 03-11-2009, 06:49 AM
My code writing software is Enroute 3 basic with an upgrade. It doesn't seem to have options for blending, or tweaking programs.
Need Help!- high speed machining code btdmfg Fanuc 4 03-07-2009 04:35 PM
Newbie- Set & Max Spindle speed code ? Jami9104 Fanuc 2 06-13-2008 05:37 AM
Need Help!- G-code speed smoothing meanshapes G-Code Programing 2 06-08-2008 12:33 AM
G-Code --- full speed BeerFizz Mach Mill 17 12-08-2007 08:06 PM
fanuc 16i-m high speed G code ??????? ramazan318186 Fanuc 1 07-23-2007 11:08 AM
