| G-Code Programing Discuss G-code programing and problems here! |
| I Have an Anderson twin spindle cnc wood router with a Fanuc om controller. I do have some programs that work fine but I am not sure what cad/cam program they were created on. I have tried using several software programs to create similar programs but there is too much code generated. Problem is when it has to cut around a 90 degree corner it slows down dramatically. (At the moment I am using Vectric software which is a pleasure to use) As the machine memory capacity is not great I prefer to drip feed. Would it be the post processor that may need modifying or is there another program that may be better suited? Any help would be greatly appreciated |
| You might take a look at OneCNC XR3. In the stock toolpaths (simple pocketing and profiling), the post processor outputs arc code for arcs, instead of interpolating into line segments, which is where the bulk of excessive code comes from. In 3d surfacing, it still outputs line segment code because it is necessary to do so.
| Vectric's posts can be configured to output arcs. I modified the Fanuc Inch post to use arcs. I didn't realize you're probably using mm's, but if you open the post your using it's easy to copy and paste the arc parts.
| Wierd NC Code and G-Code | Tazzer | General CAM Discussion | 10 | 01-09-2012 01:07 PM |
| To hand Code? or to CAD Code? | automizer | Polls | 81 | 11-26-2011 09:30 PM |
| learning g code or cad-cam code output? | slow_rider | G-Code Programing | 3 | 02-27-2010 08:48 PM |
| G-code for beginners - want to learn G-code | FPV_GTp | G-Code Programing | 7 | 11-17-2008 11:25 PM |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 09:21 PM |
