Old 02-09-2009, 05:18 PM
greybeard's Avatar
greybeard is on a distinguished road
General formula using I and J for a circle, please.
Could anyone give me a general case using the diagram I have attached for the values of I and J in coding for a circle, if the tool start position is Xb,Yb ?
As my software seems to run into problems if I enter zero for the value for I, I've located the tool start position at 45 degrees from the circle center.
The value of sq.rt. 2 is permanently etched in my brain, so I have no problem in locating the tool, given the position of the center.
I'm looking for a general formula primarily to help me get a better grasp of this command, as I have found a lot of 'explanations' ambiguous.
Many thanks,
John
Name:	G-code circle.jpg‎
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
Old 02-09-2009, 05:34 PM
Half the square root of two comes into it.
If the radius is 1.0000 the X and Y distances from the start point at 45 degrees are 0.7071 which is half the square root of two. Your I and J would be the same and the +/- sign is determined by the direction of your 45 degrees; in your diagram J is positive and I negative.
This presupposes your software treats the I and J as incremental distances from the start point to the center; I believe some controllers treat the I and J as the absolute position of the center.
Old 02-09-2009, 05:42 PM
greybeard's Avatar
Originally Posted by Geof View Post
......This presupposes your software treats the I and J as incremental distances from the start point to the center; I believe some controllers treat the I and J as the absolute position of the center.
Hi Geof, and thanks. This is where I think my problem lies, and perhaps just trying each would show me how my controller reacts.
Is ther any possibility that it might treat I and J differently, one as absolute and one as incremental ?
Sounds a nightmare, but I need to consider it !
John
Old 02-09-2009, 05:46 PM
jimalb is on a distinguished road
Mathematically, you can calculate I and J as:
I = XArcCenterPoint-XArcStartPoint
J= YArcCenterPoint-YArcStartPoint
0, 90,180, and 270 degree arcs always have either I or J as zero.
Hope this helps,
Jimmy
Old 02-09-2009, 07:04 PM
John
You never know with pointy headed software types.
Old 02-10-2009, 03:52 AM
greybeard's Avatar
Thanks Geof. Now I know why my hat stays on in high winds.
Thanks Jimmy. So on my diagram, I = (Xo - Xb), and J = (Yo - Yb).
Unfortunately this is a problem for my set up - the controller seems to have a problem with a vaue of zero for I or J, and just tries to drill a hole radius = 0
John
Old 02-10-2009, 08:10 AM
ger21's Avatar
Jimmy's giving you incremental IJ. Is your control looking for absolute? Absolute IJ specify the actual center coordinates.
Old 02-10-2009, 08:40 AM
greybeard's Avatar
Hi Gerry,
I quote from the user manual - "G02 Arc clockwise, X,Y, ending coordinates, I,J, center offsets from beginning location."
So do I assume this for incremental or absolute coordinates ?
Regards
John
Old 02-10-2009, 09:00 AM
Hi Gerry,
Regards
John
I interpret this as incremental. Have you done a successful circle using non-zero values in both I and J?
Old 02-10-2009, 10:18 AM
ger21's Avatar
Looks like incremental to me too. Not sure why it won't work with a zero coordinate.
Old 02-10-2009, 10:29 AM
HuFlungDung's Avatar
Moderator
What comes to my mind, is that the TAN90° or TAN270° are undefined. So perhaps whatever formula the controller uses incorporates this trig function somehow, so it craps out when these particular angles are involved.
  #12   Ban this user!
Old 02-10-2009, 11:25 AM
Here is a technique to test.
Position the tool at what will be the hole center.
Move the radius distance in Y and something like 0.1 in X.
Now program the G02 using I-0.1 Y-(radius distance).
EDIT: Your radius comes out wrong of course with the mov e of X0.1 but if this works see if it will accept an X move of 0.001 with a corresponding I-0.001; this will have negligible affect on the true radius.
Need Help!- formula? JOptionPane CNC Machining Centers 2 06-23-2008 01:52 PM
need a formula gravy General Metalwork Discussion 4 03-29-2008 07:38 AM
looking for a Formula rusticr6 Haas Mills 29 10-18-2007 10:23 AM
What is the Formula? widgitmaster General Metal Working Machines 6 03-23-2006 10:35 PM
Formula CNCRob General CAM Discussion 3 07-01-2005 09:18 AM
