Old 01-14-2009, 03:29 PM
GEORGETOUBALIS is on a distinguished road
Question Control Plunge rate & Retract rate
Hello!
When I design a drill patern in my Cam program the G code that generate is with a general Feed-rate.
In program the Plunge rate & Retract rate fields are inactive.
also it does not include the tool feed-rate preferences.
the code that generates is something like that:
Any idea how to control the Plunge rate & Retract rate?
Lets say
Plunge rate 200
Retract rate 600
(PROGRAM NAME - 5X5 holes 2mm per 10mm )
(DATE=DD-MM-YY - 14-01-09 TIME=HH:MM - 23:05 )
N100 G17 G21 G90 G40 G80 G64 G49 G0 M05
N102 G8 P1
N104 G90 M05 Z0
N106 G52 X0. Y0. Z0.
N108 T12 M06
( 2. DRILL )
( TOOL - 12 DIA. OFF. - 0 LEN. - 0 DIA. - 2. )
N110 G54 G0 X-105.183 Y-23.882
N112 S0 M3
N114 G43 H0 Z60.
N116 Z5.
N118 G17 G99 G82 Z-6. R5. P300. F4000.
N120 Y-13.882
N122 Y-3.882
N124 Y6.118
N126 Y16.118
N128 X-95.183 Y-23.882
N130 Y-13.882
N132 Y-3.882
N134 Y6.118
N136 Y16.118
N138 X-85.183 Y-23.882
N140 Y-13.882
N142 Y-3.882
N144 Y6.118
N146 Y16.118
N148 X-75.183 Y-23.882
N150 Y-13.882
N152 Y-3.882
N154 Y6.118
N156 Y16.118
N158 X-65.183 Y-23.882
N160 Y-13.882
N162 Y-3.882
N164 Y6.118
N166 Y16.118
N168 G80
N170 Z60.
N172 G90 G49 M05 Z0
N174 G53 X0. Y0.
N176 G52 X0. Y0. Z0.
N178 G8 P0
N180 G17
N182 M30
thanks a lot
George.!
Greece
Old 01-15-2009, 11:13 AM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
You didn't say which CAM program.
Stefan Vendin
Old 01-15-2009, 11:33 AM
beege's Avatar
beege is on a distinguished road
It's a canned cycle, and Plunge rate and Retract rate within a canned cycle depends on the control being used, if you can do it at all. What control are you using? What machine?
Old 01-15-2009, 02:36 PM
its a home-made machine
Software: Master CAM X
and mach3
George.!
Old 01-21-2009, 09:07 AM
MaCroB's Avatar
MaCroB is on a distinguished road
Macro?
Instead of using a simple G82 cycle, which is only going to give you one feedrate, you can create a macro and assign variables for the options you want. We have a macro I developed last year which allows me to step peck depths, assign multiple feedrates for primary, secondary plunge and retracts. Works extremely well with the form tooling we are using.
If you need help with the coding, PM me and I'll be glad to get you started...
Old 01-21-2009, 10:05 AM
In MCX and OP manager , Right click on the tool then "Edit Selected Operations"-"Edit Common Parameters".There you can change Plunge and retract rate.
Stefan Vendin
Old 01-21-2009, 12:14 PM
Smile
OP manager..?
I am new in MCX
Just tell me the exact name and I will make a search in MCX help
thanks. a lot.!
Old 01-21-2009, 05:12 PM
Operations manager.
Stefan Vendin
Old 04-13-2009, 06:12 AM
The reason that I need to control the Plunge rate & Retract rate is for a dispense application.
In a drill pattern I need a higher Plunge rate than a Retract rate cause my drop s have to have a little more time to move away from the head. if not the head will move with the drops.
It sound a little complex but the video explain everything!
Finally I use artcam that gives a Gcode with F in every line. Then with a simple find & replace I change the Retract rate with a slower FEED.
George!
Plunge rate, effect 3D contouring speeds? Mike 1948 WoodWorking 1 11-11-2008 01:40 AM
Pierce delay and plunge rate settings. Fiero Addiction CNC Plasma and Waterjet Machines 0 07-19-2008 06:05 PM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-21-2007 11:12 PM
Pierce Delay And Plunge Rate DISCONNECTED CNC Plasma and Waterjet Machines 3 01-29-2007 08:48 PM
