Old 01-11-2009, 06:15 AM
f-bu is on a distinguished road
Fanuc 0i cylindrical interpolation
Hi all, I've got in the middle of nowhere trying exaple for cylindrical interpolation in 0i manual. Machine is VMC, additional axis A on X axis Do someone know how to assign A axis as virtually paralell to basic axis? When I assign it as parallel to X(1022.A=5), G02 X.. A.. R.. makes circle in Y and A, X is substituted by Y. When it is assigned to Y, 1022.A=6, then the circle is made on X an A, but X axis movement is increased, not A. Any practice on this?
Old 01-12-2009, 03:13 PM
JWK42 is on a distinguished road
I think Haas is similar to Fanuc. On a Haas control the code is G107 A0. Y0. Q6.
"A" is the rotary axis (A or B) "Y" is the axis to convert to rotary ( X or Y )and "Q" is the diameter of the cylinder or "R" is the radius of the cylinder. You then program your path the same as a flat surface and the control does the rest.
I am wandering if your G107 Cyl. Interp call is correct.
Can you post the code you using for mapping your cylinder.
I am picturing this as a rotary table mounted on your table, not a true in-table rotary. The linear axis is along the "X" axis and the cylinder mapping is along the "Y" axis.
Old 01-15-2009, 02:05 AM
Here is it
G1G17X0A21.F1000
G43H11Z2.S3000M3
G1Z-3.F500
G07.1A97500
G2X0A-21.R21.
(in this point X axis moves not 21mm, but 21*2*pi/360)
G07.1A0
Old 01-15-2009, 07:59 AM
I am speaking only from my experience with Haas but I don't think you use an A word in your code after you call G107 or in your case G07.1
On a Haas you program the shape of your part in X-Y-R just like you would on a flat surface and the control converts the Y value into the A value based on the Y value and the Radius (R) or Diameter (Q) of the cylinder that you enter in your G107 Y0.0 A0.0 R2.0 cylinder interpolation call line.
Here is the example from the Haas manual. This code cuts a 4.0 X 2.0 window with 0.5 corner radii in a 4.0 inch diameter cylinder. It wraps the 2.0 inch side around the Y axis and the 4.0 inch side is straight along the X axis.
O1234 (G107 TEST)
G00 G40 G49 G80 G90
G53 G00 Z0.
G53 G00 X-20.0 Y0.
G54 G00 X1.75 Y0 S3000 M3
G107 A0. Y0. R2. (TURN CLY INTERP ON AND WRAP Y AROUND A 2.0 INCH RADIUS CYLINDER)
G43 H01 Z.25
G01 Z-.25 F5.
G41 D01 X2. Y.5
G03 X1.5 Y1. R0.5
G01 X-1.5
G03 X-2. Y0.5 R0.5
G01 Y-0.5
G03 X-1.5 Y-1. R0.5
G01 X1.5
G03 X2. Y-0.5 R0.5
G01 Y0.
G40 X1.75
G00 Z0.25
G107 (TURN CYL INTERP OFF)
G53 G00 Z0.
G53 G00 X-20. Y0.
M30
cylindrical interpolation rajeshtikar General Material Machining Solutions 12 03-31-2009 12:01 PM
Cylindrical interpolation davisboys Fanuc 7 01-01-2009 08:46 AM
HELICAL INTERPOLATION in FANUC -OMC TONY252 Fanuc 3 08-22-2007 12:27 AM
Cylindrical interpolation Question???? theemudracer G-Code Programing 4 12-09-2006 01:31 PM
Fanuc 11M Helical Interpolation MrMagooo Fanuc 3 11-15-2006 09:58 AM
