Old 12-19-2008, 02:22 PM
jdgromi is on a distinguished road
Question ERROR 041 INTERFERENCE IN NRC
Hello! guys
This is my program running on my ROMI M17 Fanuc 21i. It work ok without the line N15 T0101 M08. If this line N15 is in my program a error 041 occur before the final cut G70. What's append?
Thank for your help.
N10 G90 G20 ;
N15 T0101 M08
N20 S700 M03 ;
N30 G00 X1,01 Z1,06
N40 G71 U.06 R.02 ;
N50 G71 P60 Q130 U.030 W.010 F.010 ;
N60 G00 X,505
N70 G01 Z1,032 F,006 ;
N80 X,625 Z,997 ;
N90 Z,125 ;
N100 X,505 ;
N105 Z0,0
N110 X1,0 ;
N120 Z-,25 ;
N130 X1,06 ;
N140 G42 ;
N150 G70 P60 Q130 ;
N160 G0 X3,0 Z3,0 ;
N170 M30 ;
N180 S500 M03
Old 01-01-2009, 08:41 AM
billyfriday is on a distinguished road
cutter comp
This message is to do with the cutter compensation. Try putting G42 before
N30 and remove it from N140. Also have you told the machine the correct cutter nose radius position?
Old 01-01-2009, 01:08 PM
Thumbs up error 041
Hello1 billyfriday
I will test this modification tomorrow morning.
Best Regards
Jean-Denis
Old 01-01-2009, 02:24 PM
Originally Posted by jdgromi View Post
Hello! guys
N10 G90 G20 ;
N15 T0101 M08
N20 S700 M03 ;
N25 G42
N30 G00 X1,06 Z1,06
N40 G71 U.06 R.02 ;
N60 G00 X,505
N80 X,625 Z,997 ;
N90 Z,125 ;
N100 X,505 ;
N105 Z0,0
N110 X1,0 ;
N120 Z-,25 ;
N130 X1,06 ;
N140 G70 P60 Q130 ;
N150 G0 X3,0 Z3,0 ;
N160 M30 ;
N170 S500 M03
Another thing that i would try is have the X value the same on N30 as N130 i have found in the past this does alarm the machine.
I HAVE CHANGED THE ABOVE PROGRAME TO WHAT I THINK WILL WORK
Old 01-02-2009, 08:05 AM
dcoupar's Avatar
What value is in the R offset for T01?
Help - Get interference from Plasma on my PC nicjac CNC Plasma and Waterjet Machines 13 04-01-2009 10:34 AM
Ball nut interference - X2 and CNC Fusion Clot Benchtop Machines 6 05-24-2008 10:46 PM
Specific EMI/RFI interference problem glentner General Electronics Discussion 24 10-19-2007 09:03 PM
Hf Interference Alex S.A CNC Plasma and Waterjet Machines 2 02-11-2007 06:05 PM
Electrical Interference Scratch CNC Plasma and Waterjet Machines 0 01-13-2007 10:49 AM
