Old 12-17-2008, 07:00 PM
m8kingit is on a distinguished road
g code for a circle
Just out of curiosity, can someone show me the difference in the g code that will produce a circle and the one that will produce a square with rounded corners., lol.
I've read all i think i can read about g code, now it's time to put the practical part to work, but after reading the way the radius's are set up in the book, i never really saw a g code for a circle,
please help!
thanks
Mark
Old 12-17-2008, 07:18 PM
G02 I0. J-1. Fn.n
Will (should) cause the machine to execute a full circle of radius 1.0 with the center of the circle locate -1.0 from the position of the tool when this commend is executed. I say should because the J-1. may be interpreted as an absolute position rather than an incremental distance.
There is no single G code for doing a square with rounded corners this has to be done with a combination of G02 for the corners and G01 for the sides. The actual coordinates depend on the location of the work zero but for each corner you stop the distance R back from the corner in the direction X or Y that you are travelling then after the G02 you are at the side in that axis direction but you have moved to a position a distance R along the other axis.
Make yourself a sketch if this description is a bit foggy.
Old 12-24-2008, 04:12 PM
JapieK is on a distinguished road
G112 or G113 cw or ccw
Same as:
X0 Y0 ;
G41 D(<R)X-25 Y-25
G03 X0 Y-50 R25
X0 Y0 J50
X25 Y-25 R25
G01 G40 X0 Y0
you can make it in a para or varia
gr JapieK
Old 01-08-2009, 05:31 PM
John Walker is on a distinguished road
code for circles and pockets
please help!
thanks
Mark
Have a look at these, if you are going to do a lot of that sort of work.
http://www.cncprogramdeveloper.com/T...de_macros.html
Old 01-17-2009, 09:02 PM
warfreak's Avatar
warfreak is on a distinguished road
Wink
well if u use g2 and or g3 plus I / J you can command a full circular toolpath
Old 02-13-2011, 10:00 AM
avccrml is on a distinguished road
useing g41 or g42 doing a lead in or lead out
what is the easiest way to use cutter comp while doing a lead in or a lead out doing circular interpolation
Old 02-13-2011, 05:21 PM
angelw is on a distinguished road
Cutter radius comp can't be applied on a circular move. Accordingly, I've found the method shown in the sample code below and the accompanying picture to be the most fool proof and reliable.
This bit of code is to apply a finish cut on a bore that has already been roughed. The size of the lead in/out radius is set to suite the operation, but must be => than the cutter rad comp value being used.
Regards,
Bill
G01 X0.000 Y35.000 F400
G41 G01 X15.000 Y35.000 D01
G03 X0.000 Y50.000 I-15.000 J0.000
G03 X0.000 Y50.000 I0.000 J-50.000
G03 X-15.000 Y35.000 I0.000 J-15.000
G40 G01 X0.000 Y35.000
Old 02-13-2011, 05:39 PM
dubbs is on a distinguished road
sorry guys i'm new to this all and just wanted to know whats the best way to do a circular interpulation my hole is 2.5 inches and my endmill is 1.0inch starting from the center please need some help!!!!!!!!!!!!!!!!!!!!!!!
Old 02-13-2011, 05:40 PM
its in the center of a 8 x 8 block of steel. i havent been on a cnc mill in a very long time and cant remember how to do it and im manual prgraming the thing if someone can just shoot me a quick lesson on the codes i know go3 and go2 but i and j im having a bit of trouble getting it to work for me anybody gan give me some direction or even a program
Old 02-13-2011, 06:04 PM
can anyone helpppppppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #11   Ban this user!
Old 02-13-2011, 06:23 PM
bump
  #12   Ban this user!
Old 02-13-2011, 06:38 PM
Following are two examples of cutting a 2.5dia bore. The first example does not use cutter rad comp. and the center of the 1.0 inch cutter is programmed. In both examples, it's assumed that the cutter is at X0 Y0 and down to depth.
Both examples use a Lead In/Out arc. This will avoid a mark being left on the work surface if the cutter were just fed along the circle center line to the circumference of the circle, and fed off along the same path. Using cutter rad comp is better applied using a Lead In/Out to a smaller blend arc as well.
Hope this helps.
Regards,
Bill
No cutter rad comp example
G01 X0.000 Y0.150 Fxxx
G01 X0.600 Y0.150
G03 X0.000 Y0.750 I-0.600 J0.000
G03 X0.000 Y0.750 I0.000 J-0.750
G03 X-0.600 Y0.150 I0.000 J-0.600
G01 X0.000 Y0.150
G01 X0.000 Y0.000
Cutter rad comp example
G41 G01 X1.100 Y0.150 D01
G03 X0.000 Y1.250 I-1.100 J0.000
G03 X0.000 Y1.250 I0.000 J-1.250
G03 X-1.100 Y0.150 I0.000 J-1.100
G40 G01 X0.000 Y0.150
G01 X0.000 Y0.000
circle cutting soundwaves Joes CNC Model 2006 5 11-12-2008 11:46 PM
Need Help!- G-Code outside circle Heidenhain bigtoad170 Bridgeport and Hardinge Mills 7 07-03-2008 06:29 AM
Problem- circle AngelT Mach Mill 1 06-30-2008 08:59 AM
milling a circle osomaker Fadal 7 08-13-2006 08:04 PM
Circle is it problem bunalmis Gecko Drives 1 01-14-2004 06:15 PM
