02-13-2009, 04:02 PM
Originally Posted by battwell if you have the tool entered in tool configuration and tool table the g41 g42 work really well. you must remember to do a lead in cut and a lead out cut and enter g40 on lead out before psu or poff. if for example you wanted to cut x0 to x300 with cut line on right of tool depth 10mm y0
tool change
start at x-20 y-10 g42 prf=10 (movement to start position more than half tool diameter)
x0 y0
x300
x320 y-10 g40 lead out
poff
if you wanted to cut 3mm in from edge change y to 3 instead of 0
lead in and lead out must be at least half tool diameter distance |
Ah , i understand now, thanks. Soon ill be doing new series of cabinets so i just might write a program for it. Cut in question is for door hinge but newest problem is that doors that come to my machine are not exact 90 degree and it happens that one cut is 1 mm deep and other is 5 mm. Grrrr.... Too precise machine for the rest of old machinery in process.
Originally Posted by battwell hope that helps
by the way if you reverse direction the tool still cuts to the side of the line depicted so beware! ie it will jump to other side of line just routed |
Yes it helps, thanks, and yes i had one case reverse-direction-without-reverse-side. I had i U-like shape cut out and on exit it wasnt nice(it was braking wood) cut so i figured out to reverse path. BTW , that problem i solved with drilling two holes on the edge of exit and entrance point prior to milling. Not really standard solution but it works.
Originally Posted by battwell if you look on utube, search biessebod (me) it will show a panel being routed where you can clearly see lead in lead out on cuts YouTube - biesse cnc making pool table |
I saw your video maybe two months ago when i was thinking that we will be getting 321r so when i googled i found your video. Interesting tool deposit, i have on mine machine similar box, dont know whats inside  . Vacuming of chips is good, i presume? I have problem with that on rover 23, vacuming tubes are too far away from tools and cant suck chips. |
