Old 11-21-2008, 02:24 AM
Martynas2 is on a distinguished road
Heidenhain iTNC530, how to change plane?
Hello,
Our company have Bridgeport VMC1000XP (3 axis, iTNC530). Few days ago, we bought "angle head" for horizontal drilling (http://www.madaula.com/index-metal.p...6&categoria=49 CAD-1). But I don't know how to change plane, for example from XY, to ZY. Can somebody help me, and post here examples of programas with diferent planes?
This is simple drilling program:
0 BEGIN PGM DRILL MM
1 ; [...] !
2 ; DATE - 04-06-08
3 ; TIME - 10:11
4 BLK FORM 0.1 Z X+0 Y+0 Z+0
5 BLK FORM 0.2 X+0 Y+0 Z+0
6 TOOL DEF 1
7 TOOL CALL 1 Z S700
8 L X+9,1 Y+0 R0 FMAX M3
9 L Z+5 R0 FMAX M8
10 CYCL DEF 200 DRILLING ~
Q200=+3 ;SET-UP CLEARANCE ~
Q201=-20 ;DEPTH ~
Q206=+60 ;FEED RATE FOR PLNGNG ~
Q202=+6 ;PLUNGING DEPTH ~
Q210=+0 ;DWELL TIME AT TOP ~
Q203=+0 ;SURFACE COORDINATE ~
Q204=+5 ;2ND SET-UP CLEARANCE ~
Q211=+0 ;DWELL TIME AT DEPTH
11 L X+0 Y+0 R0 FMAX M99
12 L X+0 Y+55 R0 FMAX M99
13 L Z+5 R0 FMAX
14 M9
15 M5
16 L Z+0 R0 FMAX M92
17 M30
18 END PGM DRILL MM
Can somebody change it?
I tried cycle 19, and special fuction PLANE, but machine showed errors.
(With cycle19 error was "Locked axis was programmed)
(with PLANE "Plane function not posible")
Thanks.
Old 11-23-2008, 09:58 AM
u40304119 is on a distinguished road
1 ; [...] !
2 ; DATE - 04-06-08
3 ; TIME - 10:11
6 TOOL DEF 1
9 L Z+5 R0 FMAX M8
Q201=-20 ;DEPTH ~
13 L Z+5 R0 FMAX
14 M9
15 M5
17 M30
18 END PGM DRILL MM
change toolaxis in toolcall line input the axel paralell to the tool
it will change feeding movments when milling or drilling
Need Help!- 4th Axis Surfcam post for Heidenhain iTNC530 jfrandsen Post Processor Files 1 11-07-2008 11:12 AM
DMU 50 Evo Linear iTNC530 - Setup Program Needed Lackey92 Deckel, Maho, Aciera, Abene Mills 3 11-18-2007 10:13 PM
iTNC530 4th axis post for MCX2 Vicros Post Processors for MC 2 07-30-2007 09:51 AM
construction plane and tool plane nervis1 Mastercam 9 11-04-2004 11:53 PM
cycles initial plane/retract plane HuFlungDung OneCNC 25 06-26-2003 07:02 PM
