| G-Code Programing Discuss G-code programing and problems here! |
| I run a okuma-howa 35-l with a fanuc 18-t control.I need to know if anybody knows the parameter to set this and what is the code used in a program to lock and unlock the machine.Thank you any help will be useful. Last edited by fisholie; 11-04-2004 at 06:37 AM. |
| Not sure about the parameter, but if you want to lock the spindle from spinning and orient it, it's M19 in the program, or from MDI.
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Where did you put the M19 in? In the program? In MDI?
| The okuma manual should tell you what functions and M codes etc they have implemented. Fanuc have Many many pre-assigned functions and it is up to the Machine tool builder to use them (or not) how he sees fit. For example all M codes and special functions which can be set by a simple switch such as MLK (machine lock) are implemented through the I/O or ladder section and are machine-tool-builder dependant, they cannot usually be set by parameter. There is a whole raft of Fanuc manuals that the end-user does not usually get, he usually gets the Operator manual & Maintenance manual if he is lucky, some times he just gets the Machine tool builder version. Just to confuse things but are usefull, Fanuc have an OperatOR as well as a OperatION manual, and a ConnecTION & ConnectING manual as well as Servo man. & others which can be usefull for trouble shooting etc. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 10:21 PM |
| parametric programming | Karl_T | CamSoft Products | 21 | 05-24-2005 03:58 PM |
| G CODE programing | mold tech | G-Code Programing | 2 | 01-31-2005 01:48 PM |
| I need sample G code program | bunalmis | G-Code Programing | 1 | 08-24-2004 04:50 AM |
| Getting The Most Out of CNCzone's Posting Features | CNCadmin | CNCzone.com FAQ | 0 | 03-02-2003 12:08 AM |
