Old 11-07-2008, 05:38 AM
edward5 is on a distinguished road
Question feed overide lockout?
Hi, I am trying to find a way to speed up the retract on a tap cycle. Thought about using go1 but could cause problems if someone overides the feed. I am fairly new to programming any ideas are appreciated Thanks.
Old 11-07-2008, 06:41 AM
cogsman1 is on a distinguished road
This is how I made the machine ignore the overide on a Mitsubishi control.
#3004=3 (SHUT OFF OVERRIDE)
Tap cycle
#3004=0 (TO turn overide back ON)
Old 11-07-2008, 09:42 AM
dcoupar's Avatar
What control do you have?
Old 11-07-2008, 01:29 PM
MaCroB's Avatar
MaCroB is on a distinguished road
Depends on the controller
Most machine controllers use a parameter to enable retract speeds for tapping cycles. Your best bet to find out if you have that option and what parameter you need to change, I would contact the control manufacturer for your machine. They should be able to get an answer for you quickly...
Old 11-08-2008, 04:59 AM
I would like to try it on a mazak and a fanuc, the fanuc is about 5 years old not for sure on the mazak
Old 11-08-2008, 08:41 AM
dcoupar's Avatar
What model Fanuc?
Spindle Lockout JTulley Tormach PCNC 0 11-06-2008 06:35 AM
feed overide (bridgeport boss 4) jodybo Bridgeport and Hardinge Mills 3 03-25-2008 07:38 AM
BRIDGEPORT RAPID/FEED RATES OVERIDE 99bluemoon Bridgeport and Hardinge Mills 0 02-07-2008 11:18 AM
Feed Overide 999% Ceramic Man Haas Lathes 15 01-18-2008 08:13 AM
Feed Rate Overide problem Moondog Machines running Mach Software 0 06-14-2006 05:35 AM
