Old 10-28-2008, 03:18 PM
INXS is on a distinguished road
Angry G112 NEED HELP TURNING ON PARAM MIYANO OT
I HAVE A MIYANO BND34S2 WITH FULL C AXIS ON MAIN AN SUB SPIND. BOUGHT IT USED AN I GUESS THEY ONLY MADE 5 OF THESE WITH C AXIS. IT HAS AN OT CONTROL AND FANUC SAYS G112 IS AN OPTION FOR THAT CONTROL, HOWEVER NEED TO GO THROUGH MIYANO TO GET IT TUNED ON. MIYANO SAYS G112 CAN'T BE DONE. I KNOW IT NEEDS TO GET TURNED ON IN TH E 917 PARAM. CAN ANY ONE HELP?
Old 10-30-2008, 07:53 AM
stevo1 is on a distinguished road
I don't know much about the OT control but from what i have seen you should just be able to change the bit you want. Do you know which bit you need from the 917. What is the G112 description.
Stevo
G112 NEED HELP TURNING ON PARAM INXS General CNC (Mill and Lathe) Control Software (NC) 0 10-28-2008 02:48 PM
Need Help!- Function to change DGN/PARAM from macro? padobranac Fanuc 4 10-12-2008 04:06 AM
Fanuc param 923 problem ?? trotsky Fanuc 3 06-22-2007 09:36 AM
Fanuc motor # for param 8420 OMC OC_ Fanuc 0 02-20-2007 04:55 PM
G112 CatCAD G-Code Programing 6 12-04-2006 04:12 PM
