Old 10-13-2008, 05:47 PM
eurosoftjohn is on a distinguished road
tool head rotation about z-axis
I am trying to program a glass cutting table to cut arcs. The problem is I need to change the orientation of the tool head (it's a steel wheel) to achieve proper scoring of the glass. For linear movements the C-codes work fine to rotate the tool head right before a G00 command. But for arcs I'd need a continuous adaptation of the tool angle to the tangential direction of the arc while it is executing the G02 or G03 command. Any ideas ?
Old 10-14-2008, 07:22 AM
Andre' B is on a distinguished road
Break your g2/3 moves up into very short little g1 moves.
Old 10-14-2008, 12:46 PM
Playing around over lunch.
If you are in to doing macro B programming you could do something like this.
The macro stuff could be put in a sub program and called with G65 or G66 in place of your G2 and G3 codes.
On some controls you may even be able to redirect the G2 G3 codes to call your own subs.
The stuff shown uses absolute arc centers but a little rewriting you could change that to incremental.
Edit: The C words are commented out because the backploter does not deal with them well.
Code:
G0 X1.5 Y-1.0
G1 X1.5 Y1.0 (C0.0)
G1 Z-0.005
#100=0   (ARC START ANGLE)
#101=90  (ARC END ANGLE)
#102=1   (ARC X CENTER)
#103=1   (ARC Y CENTER)
#104=0.5  (ARC RADIUS)
#105=90 (NUMBER OF STEPS)
#106=#100
#107=[[#101-#100]/#105]
WHILE [#105 GT 0] DO1
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
G1 X[#102+#108] Y[#103+#109] (C#106)
#105=#105-1
END1
G1 X-1.0 Y1.5
#100=90   (ARC START ANGLE)
#101=180  (ARC END ANGLE)
#102=-1.0   (ARC X CENTER)
#103=1.0   (ARC Y CENTER)
#106=#100
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
#105=#105-1
END1
G1 X-1.5 Y-1.0
#100=180   (ARC START ANGLE)
#101=270  (ARC END ANGLE)
#103=-1.0   (ARC Y CENTER)
#106=#100
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
#105=#105-1
END1
G1 X-1.0 Y-1.5
#100=270   (ARC START ANGLE)
#103=-2.0   (ARC Y CENTER)
#104=-0.5  (ARC RADIUS)
#106=#100
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
#105=#105-1
END1
G1 X-0.5 Y-2.5
#101=360  (ARC END ANGLE)
#102=0.0   (ARC X CENTER)
#103=-2.5   (ARC Y CENTER)
#105=180 (NUMBER OF STEPS)
#106=#100
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
#105=#105-1
END1
G1 X0.5 Y-2.0
#100=360   (ARC START ANGLE)
#102=1.0   (ARC X CENTER)
#106=#100
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
#105=#105-1
END1
G1 X1.0 Y-1.5
#106=#100
#106=#106+#107
#108=#104*COS[#106]
#109=#104*SIN[#106]
#105=#105-1
END1
Need Help!- Macro for B-Axis rotation NL2000 G-Code Programing 9 03-24-2008 04:19 PM
Integrex tool rotation ajl6549 Mazak, Mitsubishi, Mazatrol 1 12-28-2006 07:32 PM
A axis continues rotation ? thirty78 G-Code Programing 4 12-13-2006 01:47 PM
X axis to A rotation quemast G-Code Programing 6 06-17-2006 08:36 PM
5th Axis head rotation questions. whiteriver DIY-CNC Router Table Machines 0 11-19-2005 01:07 PM
