| G-Code Programing Discuss G-code programing and problems here! |
| Hi, I am using a Fagor 8055 CNC on a laser cutter. I am actually working on porting to the Fagor control to an OEM CNC. I am trying to understand how the Fagor control oem m-codes are written. For example, an M14 means that I have selected Oxygen as the cutting gas. What I want to know is where under the file system is the M14 programmed to select the correct solenoid to allow oxygen to be supplied to the cutting head. I need to know that type of operation since the oxygen selection is a simple application/example of what I need to achieve. There are other more complex operations that I need to understand later down the track and implement under my OEM control. Thanks for your help. |
| Need Help!- Fagor Twin Spindle cnc programming | oni666 | Wood Lathes / Mills | 4 | 03-05-2008 02:21 PM |
| learning G code programming | ldaniels | Mach Wizards, Macros, & Addons | 0 | 05-08-2007 01:47 PM |
| fagor programming? | Fraggle | G-Code Programing | 2 | 12-23-2006 05:44 AM |
| Fagor 8055 Mill Sample Code and Helical Interpolation | sailcam | G-Code Programing | 3 | 10-12-2006 06:37 AM |
