| G-Code Programing Discuss G-code programing and problems here! |
| Hi all, first time posting here, please be kind ![]() Here's my problem: when I run a program with G02/G03 X Y R, everything is fine, but if I use the I and J code machine goes in "Alarm 21 wrong plane....." The machine is a Kira 40HB with Fanuc 21 control. This programs run perfectly fine on a Makino. Change the programs to R would take alot of time, so if I can find the way to get the machine to read the I and J code it would be great. I think, but I'm not sure, one o more parameters need to be switched on to enable the control to read the I and J code. Any help please will be very much appreciated. Cheers |
| Looking at a pic of your machine it appears the spindle is in the Y axis, I am unfamiliar with this type of machine but maybe you are working in the XZ plane(G18) and therefor the plane needs to be specified at the start, do you have to programme zx moves instead of xy ? Regards Stu. |
| Guys, Thank you all for your posts. Yesterday when I came across the problem I didn't have time to look at it carefully. I tried a few things today and found that actually the problem is different. The machine read without problems I and J codes in G02/G03 cycles. The problem is it doesn't aloud a Z movement in G02/G03 mode. This even if I use the R code. And that's what my programs do. the alarm is "021 ILLEGAL PLANE AXIS COMMANDED" Yes, it is a 3 axis horizontal machine with index table Stu. And it has a X Y and Z movement in the G2 command here is part of the prog: X119.829Y-30.36 Z1. G1Z0.F800 Y-26.64Z-.314F2200. G2X112.014Y-26.568Z-.994I-3.829J8.64 G1Y-30.432Z-1.32 G2X119.829Y-30.36Z-2.I3.986J-8.568 G1Y-26.64Z-2.314 G2X112.014Y-26.568Z-2.994I-3.829J8.64 G1Y-30.432Z-3.32 G2X119.829Y-30.36Z-4.I3.986J-8.568 G1Y-26.64Z-4.314 G2X114.195Y-27.276Z-4.8I-3.829J8.64 X112.014Y-26.568R9.45 G1Y-30.432 Those are proven programs of jobs that I run an a Makino machine, but now need to run on this Kira I think the machine is capable to execute a Z movement in G02/G03 and it would save me lots of time avoiding to repost the progs. Any idea/suggestion? Ta. |
| See if you have 9930 bit #3 set to 1, if not you may have to 'purchase' it from Fanuc. Al.
| Fanuc 6m doesn't read # + = | 69owb | Fanuc | 1 | 08-12-2008 10:18 PM |
| 10T-F READ READ READ READ READ READ | dcoupar | Fanuc | 3 | 03-27-2008 05:39 PM |
| Please read: PPE - not just for show. | Awsum O | Safety Zone | 2 | 05-18-2007 09:59 AM |
| Read ahead | M-man | Fanuc | 2 | 05-10-2007 09:07 AM |
| Must Read for All | CBNDude | Product Announcements & Manufacturer News | 16 | 07-21-2005 09:14 PM |
