| G-Code Programing Discuss G-code programing and problems here! |
Hi all, im new so please be nice. I am running an ibarmia ZV50 L5000 (x5000mm,y600mm,z900mm) we have a 4th axis fully intergrated on it running parralell to the x axis so the axis is defined as the A axis. My problem is i have never used a 4th axis before and i am lost. i wont to move in both X axis and A axis at the same time to make in affect a screw of 221mm pitch, outside dia 250mm insde tread dia 180mm. My question how do i lock the x and a axis and how do i get the a axis to do 1 revalution for 221mm of x movement?????????? the machine is running siemens 840d not sure which version but the machine is brand new so i am guessing the seimens bit is also new |
I run a 5-axis with Siemens 840D, I don't have any idea how your machine is setup, but the way I would do this is below. This assumes you are starting at the face of the part (221.0 mm) so the face of the part is X=0.0, & working your way toward the chuck is in the negative direction, the A-axis 0.0 is the center of the A-axis chuck/collet, & that you allow room to keep the tool from crashing into the face of the part & the chuck. When working with the A-axis & X-axis in the same line of g-code the machine goes by the rotational axis (A-axis) for it's Feed value (F=0.1), run low values on the feed or it will look like the machine is trying to cut in Rapid motions. This is only an example:
Same code as above with comments:
__________________ Free DXF Files - Vectorink.com - myDXF.blogspot.com |
| Cheers Switcher your programme worked fine obvious now i have got it working. i was trying to only do 1 pitch so didnt see the need to use a G91 this was the only differance between our programmes. cheers for the help its much appreciated |
| Looking for Siemens 840D support | psevin | Employment Opportunity | 0 | 12-05-2007 09:56 AM |
| Network and siemens 840D | meconer | General CNC (Mill and Lathe) Control Software (NC) | 4 | 10-25-2007 01:56 PM |
| VB & Siemens 840D | Thunder | Visual Basic | 1 | 09-22-2007 10:28 AM |
| Need Help, Siemens 840d Right Angle | montyleeclark | Post Processors for MC | 1 | 07-19-2007 09:23 AM |
| Siemens 840d how can i make??? | cristalex_it_sr | General CNC (Mill and Lathe) Control Software (NC) | 2 | 06-30-2006 11:01 AM |
