Old 09-26-2008, 09:06 AM
dhanesh is on a distinguished road
thread burr
we are working with aluminium 6075
while doing the threading in fanuc we are having burr at the thread starting
can any body help me in solving this
Old 10-02-2008, 01:28 AM
eject_21 is on a distinguished road
We usually re-run our finish turn after the threader,(just over the threads) and down the thread relief behind the last thread, then jump up over the top of the threads and back to the front of the threads and cut down the front of the threads following the same path but in the opposite direction (towards the face of the part).Hope this helps.
Old 11-02-2008, 07:42 PM
hongjianming is on a distinguished road
Smile
holle
you can turn the part after threading, than thread again. hope to solve it
Old 11-03-2008, 09:55 AM
g-codeguy is on a distinguished road
Use a ground turning insert. Re-cut chamfer from the thread top towards the thread root (after threading). Won't be a need for re-thread on that material.
Old 11-15-2008, 10:58 PM
chuy's Avatar
chuy is on a distinguished road
I'm assuming your making a 45 deg chamfer at the beginning of the threads at the actual thread lead.. change to a 60 deg still same size as the lead . should eliminate your problem
Old 11-17-2008, 07:23 PM
gene rhodes's Avatar
gene rhodes is on a distinguished road
ever notice how there are soo many different ways to get the same result? I do agree with the 60 deg. response, as this will allow more angle to be present on the thread major surface...but I will say that we have not had any problems with the 45 deg. approach, so long as the chamfered area is at least .06" wide. JFWIW.
Need Help!- how to drill burr free holes in aluminum springlakecnc General Metalwork Discussion 6 09-10-2008 06:13 AM
Burr Free drilling in 5052 aluminum Texiwi General Metalwork Discussion 0 06-11-2008 04:07 PM
Em throwing off a big burr Vern Smith Haas Mills 12 01-23-2008 04:38 PM
Need DIY flow through system for Burr King mp- Mass finishing equipment/media/stratigies 1 11-20-2007 02:05 PM
