Old 09-19-2008, 08:51 AM
Lugy is on a distinguished road
G38 Rectangular pattern probs
Hi, I'm working on a program to do a grid of C'Bores, 130 holes long and 5 deep. My datum is the top left and my first position is X-10.555Y-7.925
Here is my code. What is happening is it will do the first C'Bore (RHS Grid) then jump straight to the next set of C'Bores and do the same again(LHS Grid). It isn't doing the grid. I'm starting to struggle with finding the flaw. I thought it was the G36/G36.1 in the subroutine that was giving me the problems but I can't see what the matter is. Anyone else spot it? Maybe I can't see it for looking at it
:T19M06
G00Z150.0
M01
S8000M13
(MSG, 6mm carbide slot drill)
(MSG, rhs grid)
X-10.555Y-7.925
Z3.
g38u-9.53v-9.49i13j5
(cls,"hole",D7.65 Z4.4 F400)
g37
g00Z100.0
(MSG, lhs grid)
X-133.95Y-7.925
Z3.
g37
g00Z100.0
g98.1 x500 y0
M02
(dfs,"hole",P2)
G36P2
g01z-[&Z] f[&F]/2.5
g41g91x[&D]/2 f[&F]
g03.02 x0y0 i-[&D]/2j0
g40G01 x-[&D]/2
g41x-[&D]/2 f[&F]
g03.02 x0y0 i[&D]/2j0
g40G01 x[&D]/2
g90g00Z3
G36.1
(ens)
Old 09-22-2008, 03:06 AM
Well I can say I found the flaw. Turns out it was a simple problem I had put negative value "I" and "J" words in at the controller. The program's working a treat now
Never overlook the simple things!!!!!
:T19M06
G00Z150.0
M01
S8000M13
(MSG, rhs grid)
X-10.555Y-7.925
Z3.
g37
g00Z100.0
(MSG, lhs grid)
X-133.95Y-7.925
Z3.
g37
g00Z100.0
g98.1 x500 y0
M02
(dfs,"hole",P2)
G36P2
g01z-[&Z] f[&F]/2.5
g41g91x[&D]/2 f[&F]
g40G01 x-[&D]/2
g41x-[&D]/2 f[&F]
g40G01 x[&D]/2
g90g00Z3
G36.1
(ens)
Old 09-22-2008, 03:31 AM
Ok so I lie, that never worked. If I substitute the subroutine (cls,"hole",D7.65 Z4.4 F400) with a G83 deep hole drilling cycle it works fine, but when we introduce the drilling cycle we are get the same problem as before. So therefore it must be a problem with the subroutine, yes? Can anyone see any problems with it?
G34 rectangular box key program help Superiorforge G-Code Programing 6 09-13-2008 10:57 AM
303 rectangular bar source needed zcases General Material Machining Solutions 1 04-03-2008 05:03 PM
Lazy Cam probs DRP Screen Layouts, Post Processors & Misc 0 09-10-2007 03:37 PM
diy vmc from rectangular steel tubing ? andy55 Vertical Mill, Lathe Project Log 7 01-02-2006 03:59 PM
rectangular pocket macro mistux G-Code Programing 0 11-01-2005 11:54 AM
