| G-Code Programing Discuss G-code programing and problems here! |
Hi guys I am very rusty when it comes to manual programming(I always used work NC to generate my programs) I am on a Giddings and Lewis post mill using a GE Fanuc 160I control.I am trying to program a rectangular box key 4" long by 4" wide with a depth of 2 inches could someone write a program example using those dimensions.That would help me get started as I have alot of different box keys to do.My company is to cheap to buy mastercam or any other conversion software.Thanks Shawn. |
No macro b and its an inside pocket 4" wide 4" long by 2" deep. |
| well this is how I would long hand wright the program for a 2" cutter. xy zero center of the pocket z zero top of pocet O0000 (customer) (part #) (part description) G0G90G40G17 G91G28Z0(SAFE START) G28X0Y0 N100M01 T1M6 (2" INSERT CUTTER) (BODY #) (INSERT #) G0G90G54X.5Y0S0000M3(POSITION TOOL OVER STAT POINT TURN SPINDAL ON AND CALL WORK OFFSET 54) G43H1Z.1M8(BRING TOOL TO .1 ABOVE POCKET) G1Z-.2F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-.4F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-.6F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-.8F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-.9F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-1.F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-1.2F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-1.4F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-1.6F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-1.8F5.(z FEED) M98P100(RUN SUB PROGRAM) G1Z-2.F5.(z FEED) M98P100(RUN SUB PROGRAM) G0G28Z1.M9(SEND Z HOME) G91G28Y0(SEND Y HOME) T1M6 M99P100(LOOP TO N100 TO SKIP SAFE START) % (SUB PROGRAM) O100 G41D1X1.F? Y1. X-1. Y-1. X1. Y0 G40X.5 I hope this helps you if if not sorry Kyle
__________________ You must remember that 99% of my posts are Bullchit! |
| another way of doing this is i modified get lucky's prog a bit Did not look at the math just the program format O0000 (customer) (part #) (part description) G0G90G40G17 N100M01 T1M6 (2" INSERT CUTTER) (BODY #) (INSERT #) G0G90G54X.5Y0S0000M3(POSITION TOOL OVER STAT POINT TURN SPINDAL ON AND CALL WORK OFFSET 54) G43H1Z.1M8(BRING TOOL TO .1 ABOVE POCKET) Z.01 M98P100 L10(RUN SUB PROGRAM 10 TIMES ) OR ( FOR OLDER FANUC CONTROLS) M98P00100100(RUN SUB PROGRAM 10 TIMES ) G0Z.1 MOVE TO NEXT LOCATION Z.01 M98P100 L10 G0Z1.M9 G91G28Z0(SEND Z HOME) G91G28Y0(SEND Y HOME) M30 % (SUB PROGRAM) O100 G91 G1Z-.201F*** G90 G1G41D1X1.F? Y1. X-1. Y-1. X1. Y0 G40X.5 M99
__________________ If you can ENVISION it I can make it |
| 303 rectangular bar source needed | zcases | General Material Machining Solutions | 1 | 04-03-2008 05:03 PM |
| Need help turning small rectangular CR1018 | Tat2nu | General Metalwork Discussion | 8 | 07-10-2006 11:37 PM |
| rectangular tube 1/16th wall...tap or thru | slp_prlzys | Mechanical Calculations/Engineering Design | 16 | 06-22-2006 06:55 AM |
| diy vmc from rectangular steel tubing ? | andy55 | Vertical Mill, Lathe Project Log | 7 | 01-02-2006 03:59 PM |
| rectangular pocket macro | mistux | G-Code Programing | 0 | 11-01-2005 11:54 AM |
