| G-Code Programing Discuss G-code programing and problems here! |
Hi, I want to make a new M code on by ladder M code is Example M49 Write Mdi Panel Input M49 then Machine read some variable is it possible Like This M49 = #500= #1 who body tell me? Thank you very much. |
| What kind of control are you on? I can't tell you about writing it to the ladder but you can make a custom M code if you have Macro programming on your control. The way to find out is go in MDI mode type in #1=5 EOB/Insert cycle start. Look at your variables, if #1=5 then you have macro programming. Do not hit reset before looking at the variables. If you do have it there are custom macro parameters that you can set to call a specific program using whatever M-code you choose. For example if you set the M49 to call program 9020 everytime that you program a M49 it will call and read program 9020. In program 9020 you can put any information you want to read or write. Like what you wanted. O9020 #500=#1 M99 Stevo |
thank you for your quickly answer, I make a custom Macro M code But I dont wants used to Prm 6080 and Prg 9020 I want only on the ladder making new M code is it possible like to read custom variable |
| I am not sure if that is possible. My experience with ladders is limited. This is probably a question for the ladder guys. I believe that when you set up a M-code in the ladder you are able to see and set system variables inputs and outputs but I am not sure about the custom variables. Is there a reason that you don't want to use the macro programs? No offense but I hate it when everything is written to the ladder. You have no flexability unless your ladder is through F-rom and you have ladder software. I am currently dealing with a machine that has EVERYTHING written to ladder and it is Eprom so it would have to be reburned in order to change it. I am not sure who did it but it's little things like If you try and call a tool that is already in the spindle the ladder alarms out . Everybody has there own style.Sorry I was not much help. Stevo |
| fanuc-o ladder | Bill Clark | Machine Problems, Solutions , Wireless DNC, serial port | 9 | 09-29-2011 01:35 PM |
| Ladder on 0T | guhl | Fanuc | 4 | 08-17-2008 10:15 PM |
| PMC-LADDER | CHANDRU | Fanuc | 2 | 12-13-2007 09:17 PM |
| Can you make G-Code With Corel | Biggermens | General CAM Discussion | 6 | 10-29-2005 10:15 PM |
| Trying to make this work- G code | WOODKNACK | TurboCNC | 17 | 06-10-2003 12:00 PM |
