Old 08-22-2008, 10:12 PM
vladdy's Avatar
vladdy is on a distinguished road
Interactive Entry??
Looked and searched here, but didn't find anything that seemed to fit...
anyways...
My question, is interactive data entry possible???
application is plasma table,
Mach3 control software..
basically I'd like to see a prompt such as "Input Desired IPM Feed Rate"
and then be able to enter desired rate, and have the gcode update, or be applied..
When I use it, there are quite a few times that I cut the same part out of different thicknesses of material...
right now I just edit it, but interactive would be "nicer' if possible
thanks
Old 08-22-2008, 11:28 PM
Al_The_Man's Avatar
Maybe initially program a mean or maximum feed rate, then use a M0 with a prompt message at that point, then adjust the feed rate override to the desired rate.
Then cycle start to continue.
Looking for an Entry Level CNC machine pk_volt General Metal Working Machines 4 06-19-2008 01:41 AM
Celeritive Technologies Launches VoluMill Interactive™ esherbro Product Announcements & Manufacturer News 0 11-13-2007 06:58 PM
New, Free Interactive CD-ROM from SDP/SI carolpratt Product Announcements & Manufacturer News 0 12-19-2006 11:37 AM
M109 Interactive User Input axis overtravel Haas Mills 16 07-31-2006 03:55 PM
Data Entry During Machining squarewave CamSoft Products 10 03-21-2005 11:32 AM
