Old 08-11-2008, 03:48 AM
branchy is on a distinguished road
Angry SCM Record 2 problem with file transfer
I have worked on a multicam for a couple of years and decide to purchase a second hand SCM Record 2. There have been a lot of teething problems and I thought after a month I had everything covered.Not so... I am going through a post processor being DNC precision which is compatible with NUM 750. I can transfer the file no problem at all, however I am not having any luck initiating a program. I created a simple line and planned to do a dry run but had no success in anything happening at all. The following is my Gcode file.I am new to gcode as Multicam bypasses that lingo. If anyone can tell me what I maybe doing wrong I would be most appreciative. By the way the last line is the suggested block that DNC Precision use for conversing with NUM 750 to end the program
Cheers
Chris.
%1008
(Program name LINE)
G77 H6000
G77 H5000
E62000=E62000+12000 (check jig height)
G77 H101
N2 T1 M6
M40 M3 M23 D4 S16000
G0 G17 G40 X100 Y100
G1 Z50 F500
G1 X1100 F2000
G77 H102
#0D#0A#00
File Transfer problem from pc to Anilam zoeper Machine Problems, Solutions , Wireless DNC, serial port 5 03-12-2012 11:38 PM
Need Help!- Mazatrol T Plus file transfer ict Mazak, Mitsubishi, Mazatrol 1 04-22-2008 10:28 PM
File Transfer roninB4 CNCzone Club House 3 08-27-2006 11:05 AM
file transfer axis overtravel Fadal 13 01-26-2006 09:55 PM
EIA file transfer grunemh Mazak, Mitsubishi, Mazatrol 0 12-02-2005 07:45 AM
