Old 07-31-2008, 10:10 AM
Luslugger is on a distinguished road
programing G3 IJ R
This code stops with an error 39. on my okk pcv-40 meldas m86. Does this machine recognize an “R”. How do I change between incremental and absolute center of the radius? When do I use each? I have a Mach3 simulator computer program that runs the code below with out a problem.
Bob Setree 502-345-6617
L1008
N30(3/8ENDMILL)
G00G90G43G55X-1.Y.5Z1.0H30S2000M3M8
G01Z.25F50.0
G01Z-.020F15.0
X-.2Y0.0F20.
G1X0.Y0.
X.7969
X1.0306Y-.5250
X.4169Y-.3753
G3X.2126y-.4492I.3663J-.5609F15.0
G1X0.2048Y-0.4600F20.0
G1X0.Y0.F20.
X-.0890Y.2000
Y.50
X-1.0
G80M9
G40
G28Z0.0
M2
Robert Setree 502-452-9851
Old 07-31-2008, 06:10 PM
dcoupar's Avatar
I don't have a mill programming manual handy, but the Mitsubishi lathe programming manual says R is allowed, so I assume it would also be allowed for the mill.
AFAIK, arc centers are always incremental from the start point to the center. Your example appears to be using absolute center coordinates.
Old 07-31-2008, 06:38 PM
incremental always
Mitsubitsi has confirmed what you said. I have found my Mach3 program will run a demo program all the way thru that Mits will not run because the end points do not match. I am redrawing everything to check my points.
Old 08-01-2008, 12:42 AM
CNCRim's Avatar
your vector endpoint do not match to starting point...... that's why machine stop and give you alarm.
? on programing markjb Fadal 6 03-16-2009 05:09 AM
Newbie- SL-30 programing ? travis1 Haas Lathes 3 07-09-2008 09:06 AM
0-M programing help please venomgrrrl Fanuc 22 12-07-2007 11:51 PM
CNC programing Fryzss General CNC (Mill and Lathe) Control Software (NC) 8 10-27-2007 10:33 AM
CAM programing kenlambert G-Code Programing 1 02-03-2006 12:03 AM
