Old 07-31-2008, 04:32 AM
yaji63 is on a distinguished road
Finding Cut Length of a 2D & 3D Program
Does anyone have VB code to calculate the cut length of a G code program which is both in 2D and 3D forms. I do know that Cimco gives this option by default but i was trying to develop something independant of available softwares so that we can find the cut length at shop floor level.
thanks
Old 07-31-2008, 04:47 AM
irving2008 is on a distinguished road
Conceptually its not hard to do, but you'd have to interpret all the movement G codes to work out the distance travelled while also deciding if the cutter is in the work or not. Or you could just ignore all the rapids and only calculate the slow feeds on the assumption they are cutting actions although this might give an overestimate. How accurate does this need to be - do you need to include Z-traverses into/out of the work?
Old 07-31-2008, 06:50 AM
Kiwi is on a distinguished road
Here is some code that I used in a program that will give the path length.
It calculates the distance between the previous point and the current point.
You could have a number of these adding up the path lengths of different feed rates.
If F = 50 then
numDist = Sqr((X2 - X) ^ 2 + (Y2 - Y) ^ 2)
PathStep = Sqr(numDist ^ 2 + (Z2 - Z) ^ 2)
PathLength = PathLength + PathStep
End If
X2 = X:Y2 = Y:Z2 = Z
Old 07-31-2008, 07:05 AM
Khalid's Avatar
Khalid is on a distinguished road
If u have Mach3 then run the programm and then check in the 'Maintenance Hour' menu.
Old 07-31-2008, 07:11 AM
Khalid's Avatar
Here is the picture..Before dry running the G-code reset the Maintenance Hours in the dialogue by pressing the reset button.
You not require to run the machine just calculate through the software.
My 1000 cents
Name:	Maintenance Hour.JPG‎
Old 08-01-2008, 12:21 PM
Yes i do need the rapid moves also taken into account as in certain 3D programs there are lots of rapid moves generated in the NC path when i generate rest milling paths.
Old 08-01-2008, 12:29 PM
If F = 50 then
End If
Thanks a ton. I will use this and give you the feedback.
Do you know of any ways to calculate near accurate machining time with the help of programs when i also take into account the machine acceleration and deceleration ? After finding the path length this would be my target since in large 3D programs involving high feed rates, i find there is a lot of mismatch between predicted time (path length / feed rate) and actual time on the machine due to acceleration and deceleration of machine in the corners.
The problem is also with lots of rapid moves in rest milling routines.
Old 08-01-2008, 11:44 PM
If F = 50 then
End If
I have encountered a problem. The code above seems to take care of only linear moves where as my program has both linear and circular moves (G03, G03). Do you have the codes for calculating length of circular moves in all three planes ? (XY, YZ and XZ planes).
Old 08-02-2008, 12:00 AM
Originally Posted by yaji63 View Post
.................Do you know of any ways to calculate near accurate machining time with the help of programs when i also take into account the machine acceleration and deceleration ..................and actual time on the machine due to acceleration and deceleration of machine in the corners........
Unable to help any further with code.
I think you will need to gather information from your machine as different machines performances will vary.
Your code may need to analyse the path variations to include acceleration and deceleration of the machine in the corners.
Sounds quite a task.
......Do you have the codes for calculating length of circular moves in all three planes ? (XY, YZ and XZ planes).
Sorry...I don't have any code for the length of three axis arcs. I'll see what I can do.
Old 08-02-2008, 05:18 AM
.................... Do you have the codes for calculating length of circular moves in all three planes ? (XY, YZ and XZ planes).
You may need to make the variables X,X2,Y,Y2,Z,Z2,I,J,K, all Abs (eg: Abs(Z)) as not sure if this code is correct when some values have minus values.
This code should calculate the arc length.
Pi = Atn(1) * 4
If Left$(strGCode, 3) = "G02" Or Left$(strGCode, 3) = "G03" Then
StepDist = Sqr((X2 - X) ^ 2 + (Y2 - Y) ^ 2)
Radius = Sqr(I ^ 2 + J ^ 2 + K ^ 2)
Adjacent = Sqr(Radius ^ 2 - (StepDist / 2) ^ 2)
RadAngle = Atn((StepDist / 2) / Adjacent)
DegAngle = RadAngle / Pi * 180
ArcLength = Radius * 2 * Pi / 360 * (DegAngle * 2)
PathStep = Sqr(ArcLength ^ 2 + (Z2 - Z) ^ 2)
I = 0: J = 0: K = 0
End If
Tape Length??? ShortRunCNC G-Code Programing 1 05-12-2007 01:12 PM
cut to length chathorne General Metal Working Machines 0 04-25-2007 10:47 AM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
Max length of linear rod? MrBean DIY-CNC Router Table Machines 3 03-05-2005 08:47 PM
total line length program? ljoe1969 General CAM Discussion 6 01-09-2004 10:27 AM
