| G-Code Programing Discuss G-code programing and problems here! |
4 5 and 6 axis sample G Code Wanted BACKGROUND: I have completed the assembly of my 6 axis controller/container. I have integrated 2 Xylotex 3 axis controllers with a CNC4PC BOB. Its all mounted in a "cheesey" container - one of the metallic looking - but thin masonite - CD/DVD containers you can find any number of shops. Slightly bigger than a shoe box. So: I have the controllers. I have migrated to MACH3. I have the pins set up. I'd like to "dry run" the controllers with the motors connected - but on the desktop with little tape flags, before mounting up. The 3 axis checks fine -- got plenty of G Code for that. And, I can do 4 axis checks using wing foam cutting SW/files. FRUSTRATION: I've been over the 1000+ threads here on the G Code programming Forum - and no-joy. You could pm me -- or post here. I looked over the threading wizard on MACH3 and it didn't seem to get me where I thought I wanted to be. REQUEST: Does anybody have some MACH3 compatible 4/5/6 axis code they could share? TIA. Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| A configuration of the machine would help and maximum travels XYZ. Of coarse depending on how the Rotaries are wired A and B Maximum degrees would be nice too. 5 Axis with Rotary Arm 5 Axis with Trunion Table 5 Axis Tilting Head with Rotary Table Which one??
| Thanks guys - Seems like you have some experience in what I'm looking for. For now, I would say X,Y,Z, and A, B, C. A Gantry/Bridge set up with a head mounted on the Z axis and rotating axis beneath. The head on the Z would be like on Rainena's machine. The rotating axis - lathe-like aligned with the X axis (so its A) Seems like this is closest: 5 Axis Tilting Head with Rotary Table I'm sort of just looking for some sample code to check the motors and my basic configuration of the control box. Hope I understood your requests ok: As sample code, I'd think X = 48 inches max, Y = 36 inches max, Z = 12 inches max. For X, Y and Z, if the code went out to max and return to Zero, then center, that would cool. For the A axis no max revolutions envisioned in final, but for the testing 360 cw, then 360 ccw. For B and C 360 cw, then ccw. I'd expect that would be all - but need to get into the CAM lane to figure that all out. For now - just something simple to check the axes and MACH3 integration. Thanks Heaps in advance. I can check the motor/controller integration on 4 axis as I said - but would like to due a full-scale integration testing before mounting up. Jim
| Mike -- Looking forward to your help - Thanks. Toby D. Good input - thanks -- hopefully I have beeter described what I'm looking to do.
| BUMP Hoping for some help here - I am willing to check the controller setup with the motors off the system. So platform size is not so important. I would like to just run motors/controllers them with tape attached to the shafts to check that the rotation is correct. So, any X, Y, Z, A, B, C codes anyone has available would be nice. I'd be using MACH3 to check the setups. There have been similar requests for GCode examples to do the same - but all in 3 axis only - X, Y, Z. Seems like these examples would be useful to other members if posted here or in the download section of the site. Thanks, and, Jim
| 4 axis G-code Wizards available | Legacy CNC | Product Announcements & Manufacturer News | 1 | 06-25-2008 04:02 PM |
| G code help C-X axis | slkret | G-Code Programing | 1 | 05-10-2008 08:53 AM |
| zero axis key code? | drafterman | Mach Software (ArtSoft software) | 2 | 03-06-2008 08:18 AM |
| Specific (CNC) code request. | Karol | General CNC (Mill and Lathe) Control Software (NC) | 3 | 06-22-2007 09:30 PM |
| Z-Axis Arc G-Code? | GTmike400 | G-Code Programing | 16 | 01-27-2006 11:15 AM |
