Old 07-05-2008, 06:43 PM
Cartierusm is on a distinguished road
Simple problem just need an answer.
I'm using RhinoCAM and a MACH 2 post file, as I don't know if there is a MACH 3 post file. Anyway, there are two lines which mach doesn't like and I just remove them and just want to make sure it's nots going to do something weird.
N50 T1 M6
N60 G43 0
The second line I think is for tool length offset and I don't need it but want to make sure I'm not removing anything critical. Thanks.
Old 07-05-2008, 06:51 PM
ger21's Avatar
The second line is not right, should be G43 H1 where 1 is the tool number. Yes, the G43 is tool length offset. The other line should be M6 T1, it's a tool change to tool #1. If your not changing tools, you don't need either one.
Old 07-05-2008, 08:06 PM
Thanks Gerry....again! I should hire you...LOL Not the right forum but I figure I'll ask you. Since I'm having limit switches trip for no reason since I upgraded to a 48V PS, electrical noise I'm sure. I'm changing my limit switch wires to shielded should I tie all the drain wires from the shielded cable together?
Old 07-05-2008, 08:12 PM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
You can fix your post to say what you need..... If not mecsoft will fix it for you...
What do you want it to say if the program start? and End?
I use rhinocam, and could try to fix you a ppser.. I also use mach...
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Simple slot milling problem jwknow Mastercam 5 01-22-2008 05:03 PM
total noob to g-code, pretty simple (i think) arc problem. RedSoxFox G-Code Programing 19 09-30-2007 07:41 AM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
If you can ... answer this please cncbox DIY-CNC Router Table Machines 9 08-12-2005 08:50 AM
problem with a simple pocket corpse OneCNC 9 12-01-2004 12:50 AM
