Old 09-16-2004, 11:35 PM
Toddjones is on a distinguished road
Angry ID Threading
Hi all, I'm very new to CNC and have plunged into it head first. A friend of mine is a CNC machinist however is experiance is limited in lathe work as it relates to the G Codes.
We tried to perform a simple ID threading operation but I either get an Alarm or it does something weird.
Here is the code!
O0800
G20
(PROGRAM NAME - XXXXX DATE=DD-MM-YY - 16-09-04 TIME=HH:MM - 17:10 )
(TOOL - 1 OFFSET - 1)
(ID THREAD - MIN. .5 DIA. INSERT - NONE)
G0 T0101
G97 S200 M03
G0 G54 X1.05 Z-2.0358 M8
X1.2688
G99 G32 Z-4. E.8
G0 X1.05
Z-2.0403
X1.2852
G32 Z-4. E.8
G0 X1.05
Z-2.0444
X1.3
G32 Z-4. E.8
G0 X1.05
Z-2.0444
X1.3
G32 Z-4. E.8
G0 X1.05
Z-2.0358
M9
G28 U0. W0. M05
T0100
M30
My machine does not recognise G32 and I was advised to switch it to G92. It runs without an alarm using G92 however it does not perform the operation as it is suppost to. It seems to reverse the operation. My machinist said if I try running it I will crash the machine.
I am very frustrated as I need to make parts with an ID threat.
Any suggestions would be appreciated. He advised that there are no proper Post processors for HAAS lathe's and that I believe the said the closest POST processor is MFLAN.
Todd!
PS I hope I posted this in the right area!
Old 09-18-2004, 03:30 AM
tex tex is offline
tex is on a distinguished road
You should use G76 code because G92 is pretty complicated (needs more lines for more passes and is OK for a single pass). Just let us know the main parameters of the thread (F, M and depth in case it is metric) and I'll write you a code. It is even better if you send me an IGS STL or STP file of the part you want to machine and I'll do it with no trouble at all:
tex707@net.yu
A few more questions: which HAAS machine are you working on and what does the "E" command stand for?
I've tried to backplot your code and it looks strange...no feedrate at all?
There are PPs for HAAS lathes (by IMS) and in case you don't have one the closest match (99%) is FANUC6T.
Here's a simple G-code for HAAS lathe with FANUC controller that works fine:
N780 X47. Z1.
N790 M19 P180
N800 G97 S400 M03
N810 G76 D0.75 X59.4 Z-17.8 K2.6 F4.23
N820 G00 X47.
N830 Z1.
Old 10-23-2004, 01:23 AM
kbrenneke is on a distinguished road
O0800
G20
(program Name - Xxxxx Date=dd-mm-yy - 16-09-04 Time=hh:mm - 17:10 )
(tool - 1 Offset - 1)
(id Thread - Min. .5 Dia. Insert - None)
G0 T0101
G97 S200 M03
G92 X1.2688 Z-4.0 F???
X1.2852
X1.3
X1.3
M9
G28 U0. W0. M05
T0100
M30
Hope This Help
S
Old 02-20-2008, 01:20 AM
sinha_nsit is on a distinguished road
Originally Posted by Toddjones View Post
G32 Z-4. E.8
G0 X1.05
Z-2.0444
X1.3
G32 Z-4. E.8
G0 X1.05
Z-2.0444
X1.3
G32 Z-4. E.8
My machine does not recognise G32 ...
Use F for lead in the G32 block. At least in Fanuc F is used.
Old 05-22-2009, 09:08 AM
stxmuddawg is on a distinguished road
what thread are you trying to cut?
Here is the code!
O0800
G20
G0 T0101
G97 S200 M03
X1.2688
G99 G32 Z-4. E.8
G0 X1.05
Z-2.0403
X1.2852
G32 Z-4. E.8
G0 X1.05
Z-2.0444
X1.3
G32 Z-4. E.8
G0 X1.05
Z-2.0444
X1.3
G32 Z-4. E.8
G0 X1.05
Z-2.0358
M9
G28 U0. W0. M05
T0100
M30
Todd!
Old 05-22-2009, 09:24 AM
G76P020060Q20R.001
G76X(MINOR OR MAJOR DIA.)Z(DEPTH)R(TAPER IF ANY)P(THREAD HEIGHT)Q(DEPTH OF CUT)F(PITCH OR FEED)
FOR A 1/2-20 ID THREAD
LIKE THIS: G76P020060Q20R.001
G76X.5Z-.5R0P250Q20F.05
THE (R.001) IS HOW MUCH STOCK THE SPRING PASS REMOVES
THE (G76P02) THE 2 IS HOW MANY SPRING PASSES IT MAKES.
G76P020060 THE (60) ON THE END MEANS 60 DEGREE TOOL.
THE (P) IN THE SECOND LINE IS THREAD HEIGHT PER SIDE:SO (P) WOULD BE .025 OF AN INCH, BUT YOU CANNOT USE DECIMALS FOR THE (P)
Old 05-24-2009, 01:46 PM
g-codeguy is on a distinguished road
It always helps if you give the control being used at the very least. Machine you are using helps too. As already stated, F is used on Fanuc controls for threading. At least on the ones I am familiar with. We had some Hardinge CHNCs that used E, but can't recall the control model. If I recall correctly these CHNCs used G33 for threading, not G32. Pretty certain the ones we had when I first start had Allen Bradley controls and used G33.
Are you running a special thread? Must be as .0833 is a 12 pitch thread. You would need at least X1.312 for a 1-5/16 thread. Several thousandths more if using a generic insert instead of a topping one of the correct pitch for the thread being made.
G92 is not complicated to use. Easier than the G32 you are currently using. I prefer the G76 cycle so I can control compound infeed easier.
If I remember correctly, here is how a G92 is programmed:
G92X1.2688Z-4. F.0833
X1.2852
X1.3
G0G28U0W0M5
M30
Are you truly trying to thread that course of a thread in 3 passes? Not normally advisable. However I did ONE time make a 5/16 inch thread (course, but don't remember the pitch) with 3 passes in softer material as that was the only way I could eliminate chatter.
Okuma LC-20 Threading problem Gunner Machine Problems, Solutions , Wireless DNC, serial port 13 12-13-2011 11:11 PM
threading help!!! asap joe1970 G-Code Programing 5 04-16-2005 08:46 AM
Deskcnc version that supports threading Dan Mauch Carken Products (Deskam, DeskCNC etc) 1 04-04-2005 07:51 PM
Threading tool recomendation Toddjones Machine Problems, Solutions , Wireless DNC, serial port 4 02-18-2005 01:55 AM
Taig lathe Threading and CNC questions anoel Mini Lathe 5 01-12-2004 04:43 PM
