Old 06-20-2008, 06:14 PM
Shotout's Avatar
Shotout is on a distinguished road
Question on using g10 for work offsets HMC Fanuc
I have not been able to find this in the manuals for the Fanuc control (310is). We use G10 to set the work offsets, normally center or rotation of the rotary axis, but I haven't been able to find out what the L address signifies. Our programs that predate me use L2 but I'd like to understand why and how it is used. I'd appreciate any illumination that someone is willing to share.
Scott
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
Old 06-20-2008, 07:18 PM
dcoupar's Avatar
L2 specifies the standard WCS (1 to 6 - G54 to G59) (see attached .jpg)
L20 specifies the additional WCS (1 to 48 - G54.1 P1 to P48)
Also remember, G91 can be used to add or subtract from the value currently in the register.
So:
G10 L2 P2 X-12.3456 sets X of G55 to -12.3456
G10 L20 P2 X-12.3456 sets X or G54.1 P2 to -12.3456
G91 L20 P6 X-0.03 reduces the value in G54.1 P6 by 0.03.
Name:	310is Programmable WCS modification.jpg‎
ID:	61871   Click image for larger version
Name:	310is Additional WCS Setting.jpg‎
Old 06-21-2008, 08:35 PM
Shotout's Avatar
So the only values for L are 2 which sets G54-G59 depending on the P value of 1-6, or 20 which allows for 48 additional WCS that would be called in a program as G54.1 Pnn. Is that correct?
So:
Mark Twain
Old 06-21-2008, 08:51 PM
beege's Avatar
beege is on a distinguished road
No, L2 and L20 have to do with the work offsets, but other "L"s are for things like parameters, tool offsets, pitch comp, and things you usually don't want to mess with from inside a program.
Old 06-25-2008, 03:49 PM
Shotout's Avatar
OK. I appreciate the explanations thanks.
Mark Twain
Fanuc 0T Work offsets John3 Fanuc 7 10-16-2009 11:21 PM
Work Offsets RMT Mach Mill 14 12-14-2008 09:49 AM
how do you set G54 thru G59 work offsets? Barney Fanuc 10 01-07-2007 03:02 PM
work offsets 5axisdan Mazak, Mitsubishi, Mazatrol 0 07-04-2005 10:17 AM
Work Offsets new2cnc Mastercam 3 04-30-2005 10:04 AM
