| G-Code Programing Discuss G-code programing and problems here! |
Hello all. I'm new here and hoping someone can help me understand Macros. Right now, I'm totally new to them...they just seem like canned cycles (ie G81). So here's my question: 1. What is a macro good for? 2. Can someone provide a very basic macro program which i can use to see how them work? Thanks all! John |
| macros are good if you have similar parts that require only a few changes. The program below is for turning a straight OD on a vertical turning lathe. This will pick away at the OD until reaching size. By only changing the main program variables you have control over deciding what size OD you want, what size picks, how much extra stock to remove, and what size finish pass. O0115(MAIN PROGRAM) G65P8002A15B.75C1Q.1D.01T10 M30 (DESCRIPTION OF VARIABLES) A=(FINISHED OD) B=(X-STOCK OD) C=(RING THICKNESS) T=(TOOL) D=(STOCK FOR FINISH PASS) Q=(PICK SIZE) O8002(SUB ROUTINE) T#20M6 IF[#2LE0]GOTO3 G0G90G54 G96S150M4 #2=#2-#17 N1IF[#2LE0]TH#2=0 G0X[#1+#2+#7]Z.1 Z.01 G1Z-[#3+.1]F.01M8 G0U.1 Z.01 IF[#2LE0]GOTO2 #2=#2-#17 GOTO1 N2G0Z.01M9 G28U0W0 N3M0 (CHECK INSERT B/4 FINISH PASS CYCLE START) #7=0 #2=0 G0G90G95G54M41 G96S150M4 G0X#1Z.05 Z.01 G1Z-[#3+.1] G0U.1 G0Z3.M9 G28G53U0W0M5 M99 |
| As you can see from Stevo's post, macros aren't all that easy to understand if you don't have any experience with them. What Stevo neglected to tell you is that A=#1, B=#2, C=#3, D=#7 (faked you out, huh?), Q=#17, T=#20. Course these are from the Fanuc manual. I have no experience with Haas controls, and so don't know if these values are standardized. I doubt Stevo is using a Fanuc control, otherwise he probably would be using the G71 cycle, and assigning values to it. Now you can follow his program. ![]() Since you apparently have no experience with variables, my suggestion is to NOT jump right into macro programming, but start by using variables in a standard program. Then work your way to the harder stuff. That is how I taught myself. |
| Check out this thread. It has some very good discussion about Macros. http://www.cnczone.com/forums/showthread.php?t=20564 |
| Macros are very powerful. This example mills a special mixer on a plastics feedscrew. It will run 14mm up to 180mm or bigger. I have 20 or so simple questions to answer, program does all the math to find the points. Its very long but a good example of the level you can take macros. % O0100(*** MIXER) (ANSWER THE FOLLOWING) (ANSWER=0 IF NOT NEEDED) (OPPOSITE LEAD?) #501=0 (ACTUAL O.D?) #670= (ACTUAL MIXER LENGTH?) #671= (PROGRAM LENGTH?) #672= (WIPING PITCH?) #673= (BARRIER PITCH?) #674= (CROSS-CUT POSITIONS?) #675= #676= #677= (WIDTH OF CROSS-CUTS?) #678= (POSITION OF SMALL POCKET?) #679= (WIPING LAND WIDTH?) #680= (BARRIER LAND WIDTH?) #681= (FLIGHT ENDMILL DIA.?) #682= (ROOT ENDMILL DIA.?) #683= (PRINT METER B DEPTH?) #684= (PRINT METER A DEPTH?) #685= (PROGRAM CHANNEL DEPTH?) #686= (PROGRAM UNDERCUT DEPTH?) #687= (FEEDRATE?) #688= (ENDMILL SPEED?) #689= (***END OF EDIT***) #686=ABS[#686] #687=ABS[#687] #1=#686 #2=#687 #3=#688 #4=#689 #109=#670 #110=#671 #111=#672 #112=#673 #113=#674 #155=#675 #156=#676 #157=#677 #114=#678 #115=#679 #123=#680 #122=#681 #116=#682 #117=#683 #118=#684 #119=#685 #2=#2-.1 #502=#109-#2-#2 #502=[#502*3.142] #503=[#109*3.142] #198=[360/#112] #199=[360/#113] #112=ATAN[#112]/[#503] #113=ATAN[#113]/[#502] #502=#109-[#2*2] #2=#687 N2IF[#155EQ0]GOTO8 GOTO9 N8#114=0 N9IF[#114EQ0]GOTO12 IF[#116GT#114]GOTO502 N12IF[#109GT9]GOTO1 #109=#109 GOTO2 N1#109=[#109*.03937] N2 IF[#118GT.5]GOTO5 GOTO6 N5#118=#109-#118 #118=[#118/2] N6IF[#119GT.5]GOTO7 GOTO8 N7#119=#109-#119 #119=[#119/2] N8 #503=#109 #109=#502 #199=TAN[#113]*#109*3.142 #199=[360/#199] #109=#503 #197=[#109*3.142] #197=[#197/360] #196=[#123+#116] #196=#196*SIN[#112] #195=[#123+#116] #195=#195*COS[#112] #196=[#196/#197] #195=[#195*#198] #190=[#196+#195] #109=#502 #197=[#109*3.142] #197=[#197/360] #196=[#122+#116] #196=#196*SIN[#113] #195=[#122+#116] #195=#195*COS[#113] #196=[#196/#197] #195=[#195*#199] #191=[#196+#195] #109=#503 #690=[#3/2] #500=#198 #5221=#5021 #5223=#5023 #5224=#5024 G54(SET WORK COORD. ZERO XZA) #152=[#111-#110] #152=[#152/2] #152=[#152+#118+#115] #151=[#111-#110] #151=[#151/2] #151=[#111-#151-#119-#115] #150=#1-#2 #150=#150*TAN[60] #150=#151-#150 #153=#111-#150 #100=[#150*#198+360] #101=[#151*#198+360] #104=[#152*#198+360-#190] #105=[#153*#198+360-#190] #106=[#111-#153] #106=[#106*#198] #106=[#106+#105] #108=[#153-#152] #108=[#108*#199] #108=[#104+#108] #107=[#111-#153] #107=[#107*#199] #107=[#107+#108] #103=[#111*#199] #103=[#107-#103-#191] #103=#103+180 #102=[#150*#199] #102=[#102+#103] #125=#105-#108 #126=#102-#100 #127=#103-360 #128=#106-#107 #120=[#125/2] #120=#108+#120 #121=[#126/2] #121=#100+#121 N1IF[#108GT#105]GOTO10 IF[#100GT#102]GOTO11 GOTO14 N10IF[#100GT#102]GOTO500 #130=[#102-#100] #130=[#108-#105+#130] #130=[#130/2] GOTO80 N14IF[#126GT#125]GOTO15 #132=[#102-#100] #132=[#105-#108-#132] #132=[#132/2] GOTO80 N11#131=[#105-#108] #131=[#100-#102+#131] #131=[#131/2] GOTO80 N15#133=[#102-#100] #133=#133-[#105-#108] #133=[#133/2] N80#100=[#150*#198+360] #101=[#151*#198+360] #104=[#152*#198+360-#190] #105=[#153*#198+360-#190] #106=[#111-#153] #106=[#106*#198] #106=[#106+#105] #108=[#108-#130+#131+#132-#133] #107=[#111-#153] #107=[#107*#199] #107=[#107+#108] #103=[#111*#199] #103=[#107-#103-#191] #103=[#103+180] #102=[#150*#199] #102=[#102+#103] #125=[#105-#108] #125=ROUND[#125*10000]/10000 #126=[#102-#100] #126=ROUND[#126*10000]/10000 #127=#103-360 #128=#106-#107 #514=#125 #515=#127 IF[#125NE#126]GOTO500 IF[#100GT#102]GOTO20 N20IF[#108GT#105]GOTO500 IF[#108LT#104]GOTO504 #520=#198+#199 #520=[#520/2] #521=#112+#113 #521=[#521/2] #528=[#109*3.142] #528=[#528/360] #522=#117-#116 #522=[#522/2] #523=[#116/2] #524=#117-.125 #530=[#522+#523] #530=[#530*2] #530=#530+#117 #525=#530*SIN[#521] #526=#530*COS[#521] #525=[#525/#528] #526=[#526*#520] #526=#526+#525-#126 #527=[#526/#520] #540=[#524*3] #540=#540+#117 #541=#540*SIN[#521] #542=#540*COS[#521] #541=[#541/#528] #542=[#542*#520] #541=[#541+#542] #542=[#541/#520] #135=#150-#527 #136=[#522+#523-.063] #137=#135-#542 #138=[#117/2] #138=#138+#136 #139=#137-#542 #140=[#117/2] #140=#138+#140 #141=#139-#542 #142=[#117/2] #142=#140+#142 #143=#138-#136 IF[#137LT#138]GOTO1 IF[#139LT#140]GOTO2 GOTO3 N1#137=#0 #139=#0 #141=#0 N2#139=#0 #141=#0 N3IF[#141LT#142]GOTO4 GOTO5 N4#141=#0 N5#529=[#527*#199] #529=#102-#529 #600=[#527*#198] #600=#100-#600 #600=#529-#600 #600=[#600/2] #600=#529-#600 #27=[.032*#198] #600=#600+#27 #601=#135-#136 #601=[#601*#198] #601=#600-#601 #602=#135-#136 #602=[#602*#199] #602=#600-#602 #603=#600-#541 #604=#137-#138 #604=[#604*#198] #604=#603-#604 #605=#137-#138 #605=[#605*#199] #605=#603-#605 #606=#603-#541 #607=#139-#140 #607=[#607*#198] #607=#606-#607 #608=#139-#140 #608=[#608*#199] #608=#606-#608 #609=#606-#541 #610=#141-#142 #610=[#610*#198] #610=#609-#610 #611=#141-#142 #611=[#611*#199] #611=#609-#611 IF[#603LT#604]GOTO1 IF[#606LT#607]GOTO2 GOTO3 N1#603=#0 #606=#0 #609=#0 N2#606=#0 #609=#0 N3IF[#609LT#610]GOTO4 GOTO5 N4#609=#0 N5IF[#604GT#605]GOTO6 IF[#605GT#602]GOTO7 GOTO8 N6#604=#0 N7#605=#0 N8IF[#607GT#608]GOTO9 IF[#608GT#605]GOTO10 GOTO11 N9#607=#0 N10#608=#0 N11IF[#610GT#611]GOTO12 IF[#611GT#608]GOTO13 GOTO14 N12#610=#0 N13#611=#0 N14 #165=#153+#527 #166=[#111-#522-#523+.063] #167=#165+#542 #169=#167+#542 #171=#169+#542 #168=#166-#143 #170=#168-#143 #172=#170-#143 IF[#167GT#168]GOTO1 IF[#169GT#170]GOTO2 GOTO3 N1#167=#0 #169=#0 #171=#0 N2#169=#0 #171=#0 N3IF[#171GT#172]GOTO4 GOTO5 N4#171=#0 N5#575=[#527*#198] #575=#105+#575 #620=[#527*#199] #620=#108+#620 #620=#575-#620 #620=[#620/2] #620=#575-#620 #27=[.032*#198] #620=#620-#27 #623=#620+#541 #626=#623+#541 #629=#626+#541 #621=#166-#165 #621=[#621*#199] #621=#620+#621 #622=#166-#165 #622=[#622*#198] #622=#620+#622 #624=#168-#167 #624=[#624*#199] #624=#623+#624 #625=#168-#167 #625=[#625*#198] #625=#623+#625 #627=#170-#169 #627=[#627*#199] #627=#626+#627 #628=#170-#169 #628=[#628*#198] #628=#626+#628 #630=#172-#171 #630=[#630*#199] #630=#629+#630 #631=#172-#171 #631=[#631*#198] #631=#629+#630 IF[#624GT#622]GOTO1 IF[#625GT#622]GOTO2 GOTO3 N1#624=#0 N2#625=#0 N3IF[#627GT#625]GOTO4 IF[#628GT#625]GOTO5 GOTO6 N4#627=#0 N5#628=#0 N6IF[#630GT#628]GOTO7 IF[#631GT#628]GOTO8 GOTO9 N7#630=#0 N8#631=#0 N9IF[#623GT#625]GOTO10 IF[#626GT#628]GOTO11 GOTO12 N10#623=#0 #626=#0 #629=#0 N11#626=#0 #629=#0 N12IF[#629GT#631]GOTO13 GOTO14 N13#629=#0 N14#543=#114-#116 #544=[#543/2] #545=#111-#110 #545=[#545/2] #186=#155+#545 #180=#186-#544 #181=#180+#543 #550=[#180*#199] #550=[#550+#103] #551=#550+#191 #552=[#186*#199+#103] #554=[#181*#199+#103] #553=#554+#191 #565=#552+#191 #187=#156+#545 #182=#187-#544 #183=#182+#543 #555=[#182*#199+#103] #556=#555+#191 #557=[#187*#199+#103] #559=[#183*#199+#103] #558=#559+#191 #566=#557+#191 #188=#157+#545 #184=#188-#544 #185=#184+#543 #560=[#184*#199+#103] #561=#560+#191 #562=[#188*#199+#103] #567=#562+#191 #564=[#185*#199+#103] #563=#564+#191 #144=#117-#116 #144=[#144/2] #145=#144*SIN[#112] #146=#144*COS[#112] #145=[#145/#528] #146=[#146*#198] #147=#145+#146 #145=#144*SIN[#113] #146=#144*COS[#113] #145=[#145/#528] #146=[#146*#199] #148=#145+#146 #149=#117-.08 #158=#149*SIN[#113] #159=#149*COS[#113] #158=[#158/#528] #159=[#159*#199] #160=#158+#159 #581=#105-#147 #580=[#153*#198] #580=#581-#580 #582=#108+#148 #582=#582-#160 #583=[#153*#199] #583=#582-#583 #584=[#111*#199] #584=#584+#583 #586=#100+#147 #585=[#153*#198] #585=#585+#586 #587=#102-#148 #587=#587+#160 #588=[#153*#199] #588=#587+#588 #589=[#111*#199] #589=#588-#589 #585=#585-180 #586=#586-180 #587=#587-180 #588=#588-180 #589=#589-180 IF[#583GT#580]GOTO1 GOTO2 N1#583=#580 N2IF[#588LT#584]GOTO3 GOTO399 N3#588=#584 N399#510=1 IF[#604EQ#605]GOTO401 GOTO402 N401GOTO405 N402IF[#604EQ#0]GOTO403 GOTO404 N403IF[#605NE#0]GOTO507 N404IF[#605EQ#0]GOTO507 #510=[#510+1] N405IF[#607EQ#608]GOTO411 GOTO412 N411GOTO415 N412IF[#607EQ#0]GOTO413 GOTO414 N413IF[#608NE#0]GOTO507 N414IF[#608EQ#0]GOTO507 #510=[#510+1] N415IF[#610EQ#611]GOTO421 GOTO422 N421GOTO425 N422IF[#610EQ#0]GOTO423 GOTO424 N423IF[#611NE#0]GOTO507 N424IF[#611EQ#0]GOTO507 #510=[#510+1] N425IF[#624EQ#625]GOTO431 GOTO432 N431GOTO435 N432IF[#624EQ#0]GOTO433 GOTO434 N433IF[#625NE#0]GOTO507 N434IF[#625EQ#0]GOTO507 N435IF[#627EQ#628]GOTO441 GOTO442 N441GOTO445 N442IF[#627EQ#0]GOTO443 GOTO444 N443IF[#628NE#0]GOTO507 N444IF[#628EQ#0]GOTO507 N445IF[#630EQ#631]GOTO451 GOTO452 N451GOTO455 N452IF[#630EQ#0]GOTO453 GOTO454 N453IF[#631NE#0]GOTO507 N454IF[#631EQ#0]GOTO507 N455#511=#117 #512=#112 #513=#113 #514=#125 #515=#127 GOTO501 N100G04P1000 N101G9 N102M3S#689 N103G0X-#151A#101Z-.09 N104G1F2Z-#687 N105F#690X-#150A#100Z-#686 N106F#688X0A360 N107A#103 N108X-#150A#102 N109X-#151A#101Z-#687 N110G0Z0 N111X-#152A#104 N113Z-.09 N114G1F2Z-#687 N115F#690X-#153A#105Z-#686 N116F#688X-#111A#106 N117A#107 N118X-#153A#108 N119X-#152A#104Z-#687 N120G0Z0 N121X-#151A[#101+180] N122Z-.1 N123G1F2Z-#687 N124F#690X-#150A[#100+180]Z-#686 N125F#688X0A540 N126A[#103+180] N127X-#150A[#102+180] N128X-#151A[#101+180]Z-#687 N129G0Z0 N130G0X-#152A[#104+180] N132Z-.1 N133G1F2Z-#687 N134F#690X-#153A[#105+180]Z-#686 N135F#688X-#111A[#106+180] N136A[#107+180] N137X-#153A[#108+180] N138X-#152A[#104+180]Z-#687 N139G0Z0 IF[#155EQ0]GOTO176 (CROSS-CUTS) N141X-#180A#550 N142G1F10Z-#686 N143F#688A#551 N144X-#181A#553 N145F[#688+50]A#554 N146G0Z0 N147X-#182A#555 N148G1F10Z-#686 N149F#688A#556 N150X-#183A#558 N151F[#688+50]A#559 N152G0Z0 IF[#157EQ0]GOTO159 N153X-#184A#560 N154G1F10Z-#686 N155F#688A#561 N156X-#185A#563 N157F[#688+50]A#564 N158G0Z0 N159X-#180A[#550+180] N160G1F10Z-#686 N161F#688A[#551+180] N162X-#181A[#553+180] N163F[#688+50]A[#554+180] N164G0Z0 N165X-#182A[#555+180] N166G1F10Z-#686 N167F#688A[#556+180] N168X-#183A[#558+180] N169F[#688+50]A[#559+180] N170G0Z0 IF[#157EQ0]GOTO176 N171X-#184A[#560+180] N172G1F10Z-#686 N173F#688A[#561+180] N174X-#185A[#563+180] N175F[#688+50]A[#564+180] N176G0Z0M5 N178G0X0A0M9 N498M00(** TOOL CHANGE FOR ROOT **) #5223=#5023 M7 M3S#4119 (BARRIER UNDERCUT) N179G0A#580 N180Z-.09 N181G1F2Z-#687 N182F#688X-#153A#581 N183A#582 N184X0A#583 N185X-#153A#582 N186X-#111A#584 N187A#585 N189X-#150A#586 N190F[#688+100]A#587 N191X-#111A#588 N192X-#150A#587 N193X0A#589 N194G0Z0 (BARRIER UNDERCUT 180) N195A[#580+180] N196Z-.09 N197G1F2Z-#687 N198F#688X-#153A[#581+180] N199A[#582+180] N200X0A[#583+180] N201X-#153A[#582+180] N202X-#111A[#584+180] N203A[#585+180] N205X-#150A[#586+180] N206F[#688+100]A[#587+180] N207X-#111A[#588+180] N208X-#150A[#587+180] N209X0A[#589+180] N210G0Z0 N211X-#135A#600 (ROOT OUTLET CHANNEL) N212Z-.1M7 N213G1F2Z-#686 N214F#688X-#136A#602 N215A#601 N216X-#135A#600 IF[#603EQ#0]GOTO229 N217X-#137A#603 N218X-#138A#605 N219A#604 N220X-#137A#603 IF[#606EQ#0]GOTO229 N221X-#139A#606 N222X-#140A#608 N223A#607 N224X-#139A#606 IF[#609EQ#0]GOTO229 N225X-#141A#609 N226X-#142A#611 N227A#610 N228X-#141A#609 N229G0Z0 N231X-#165A#620 (INLET CHANNEL) N232Z-.1 N233G1F2Z-#686 N234F#688X-#166A#621 N235A#622 N236X-#165A#620 IF[#623EQ#0]GOTO249 N237X-#167A#623 N238X-#168A#624 N239A#625 N240X-#167A#623 IF[#626EQ#0]GOTO249 N241X-#169A#626 N242X-#170A#627 N243A#628 N244X-#169A#626 IF[#629EQ#0]GOTO249 N245X-#171A#629 N246X-#172A#630 N247A#631 N248X-#171A#629 N249G0Z0 N251X-#135A[#600+180] (OUTLET CHANNEL 180) N252Z-.1 N253G1F2Z-#686 N254F#688X-#136A[#602+180] N255A[#601+180] N256X-#135A[#600+180] IF[#603EQ#0]GOTO269 N257X-#137A[#603+180] N258X-#138A[#605+180] N259A[#604+180] N260X-#137A[#603+180] IF[#606EQ#0]GOTO269 N261X-#139A[#606+180] N262X-#140A[#608+180] N263A[#607+180] N264X-#139A[#606+180] IF[#609EQ#0]GOTO269 N265X-#141A[#609+180] N266X-#142A[#611+180] N267A[#610+180] N268X-#141A[#609+180] N269G0Z0 N271X-#165A[#620+180] (INLET CHANNEL 180) N272Z-.1 N273G1F2Z-#686 N274F#688X-#166A[#621+180] N275A[#622+180] N276X-#165A[#620+180] IF[#623EQ#0]GOTO289 N277X-#167A[#623+180] N278X-#168A[#624+180] N279A[#625+180] N280X-#167A[#623+180] IF[#626EQ#0]GOTO289 N281X-#169A[#626+180] N282X-#170A[#627+180] N283A[#628+180] N284X-#169A[#626+180] IF[#629EQ#0]GOTO289 N285X-#171A[#629+180] N286X-#172A[#630+180] N287A[#631+180] N288X-#171A[#629+180] N289G0Z0M5M9 N290X0A0 GOTO505 N499 M5 #33=100 WHILE[#33LE199]DO1 #[#33]=#0 #33=#33+1 END1 #33=500 WHILE[#33LE690]DO2 #[#33]=#0 #33=#33+1 END2 M30 N500M0 (FLIGHT ENDMILL IS TOO LARGE) GOTO499 N501M0 (CYCLE START TO FLY WITH AN ****) M7 IF[#501EQ1]GOTO899 GOTO100 N502M0 (ENDMILL DIA. TOO BIG FOR CROSSCUTS) M30 N504M0 (FLIGHT ENDMILL IS TOO SMALL) GOTO499 N507M0 (**CANNOT CORRECTLY PROGRAM ROOT**) (CHECK PROGRAM MACRO VALUES) M2 N505G04P3000 (** MIXER IS FINISHED **) M9 GOTO499 % |
| This is a simple stud. No where near as complicated as Mr. Weed's program. The 4 OD diameters are the same for each family of studs. There are 4 possible variables along its length. It may or may not get an internal configuration (depths vary also). It may or may not get cross holes drilled in the thread and/or the raceway. Material may vary from 5/8 to 7/8 in 1/16 increments. Originally had 4 programs because of stock size varying. The rough turn may or may not turn in two sections depending on the length to the first shoulder. Program needs to be changed to complete the rough turn with the Lead Angle turning tool, and only face shoulders and the face with the 80 deg. profile tool. We are trying to get more use out of the inserts. I did it quick and dirty to get the program written using the 5/8 stock size master program I already had. All diameters can be controlled by 500 series macros. Thread has to be held close so it has a variable on both ends. The diameter behind the thread might be 1/4 inch or over 2 inches long so it also gets a variable on each end. Ones that long have separate programs, tho. You will see what appears to be 2 definitions for the same dimensions. Vast majority of the time they are...but every now and then the dimensions to the shoulders are slightly different between the blank drawing and the finish drawing. Apparently the shoulders get ground on ocassion. These are only a couple of the notes in the header. MUST CHANGE #149 TO ZERO IF GOING FROM PARTS OF THE SAME LENGTH BUT HAVING DIFFERENT HOLE CONFIGURATIONS, OR IF YOU HAVE TO MODIFY A VARIABLE AFTER RUNNING THE 1ST PART. PART DESCRIPTION: .391/.389, .460/.455, AND .614/.610 DIAMETERS .290 x 90 DEG. INCL FRONT, .592 x 90 DEG. INCL REAR .035/.025 x 30, .360/.350 U-CUT, .01 x 45 DEG. CHAMFER Part description hopefully alerts operator to a stud that may have been modified from the standard for some reason. You may wonder why the G50/G96 is set by the rough turn calc. (Sometimes it isn't, depending on the job.) No matter how many times I tell some operators that G50 sets the max RPM and G96 sets the SFM, I still get called because of chatter only to find that they have been changing my starting spindle speed. Telling them that S650 sets the SFM and M3000 sets the maximum RPM seems to help them understand much better what and where they have to make changes to get rid of chatter. My rough turn calc subprogram also sets the feedrate based on the depth of cut as specified by the G65 macro call. #124 is loaded with a 3 because it is used to set the workshift which is also changed from normal if there is a cross hole in the raceway. Needs to set furnther from the collet to clear the live tool holder. This way it alarms if the operator doesn't set it correctly. (Well...he could still put the wrong number in. ):0857 (3/8-24UNJF 8620 MASTER) #115=0 (STOCK SIZE) IF[#115GT.62]GOTO1 #3000=1 (SET STOCK SIZE) (PART MACROS) N1#110=0 (FACE TO 1ST SHOULDER) IF[#110GT.35]GOTO2 #3000=2 (SET #110) N2IF[#149EQ#110]GOTO200 (SKIPS VARIABLES ONCE SET) #111=0 (END OF THREAD TO 1ST SHOULDER) #112=0 (1ST SHOULDER TO END OF PART) #113=0 (RACEWAY LENGTH) #114=#110-#111 (THREAD LENGTH) #120=3000 (RPM FINISH TURN FRONT) #101=.125+#110+#112 (C-O Z-AXIS) #149=#110 (FRONT I.D. WORK) #121=0 (7/64 IN. DRILL DEPTH, MUST BE 0 IF NONE) #122=0 (DEPTH OF .1250/.1265 HOLE) #109=.19 (CONTROLS C-DRILL DEPTH) (CROSS DRILLS) #123=0 (0 FOR NO DRILL IN THREADS, 1 IF YES) #124=3 (0 IF NO X-DRILL NEXT TO HEAD 1 IF YES) #125=0 (0 IF NO X-DRILL IN SHANK, 1 IF YES) (7/64 IN. THREAD CROSS DRILL) #130=0 (RPM-5000 FOR CARBIDE, 3300 FOR HSS) #131=.0012 (FEEDRATE IN IPR) #132=0 (FACE TO 1ST SHOULDER) #133=0 (CENTERLINE OF CROSS HOLE TO 1ST SHOULDER) (#134 FIGURES IPM FEEDRATE FOR ALL X-DRILLS) (1/16 IN. HEAD CROSS DRILL) #135=0 (RPM-5000 FOR CARBIDE, 4200 FOR HSS) #136=.0007 (FEEDRATE) #137=0 (1ST SHOULDER TO 2ND SHOULDER) #138=0 (2ND SHOULDER TO DRILL CENTER LINE) (SET WORKSHIFT) IF[#124EQ0]GOTO50 IF[#124EQ1]GOTO51 #3000=3 (SET #124 CORRECTLY) N50IF[#101GE1.3]THEN#530=#101+.4 IF[#101LT1.3]THEN#530=1.7 GOTO54 N51IF[#101GE1.8]THEN#530=#101+.9 IF[#101LT1.8]THEN#530=2.2 N54M1 N200G10P0Z-#530 (BARSTOP) G200 M1 N400M91 (L.A. TOOL/TURN .625) IF[#115LE.625]GOTO100 G65P9017X.625F.01C.012U.055U.075S900M3000 (ROUGH TURN CALC) T0404S[3.82*#119/#115]M13 X#115Z-.05 G50S#118 G96S#119 G1Z-.08F.008 G71U#116R.01 G71P11Q12F#117 N11G1X.625 U#518Z-[#101+.17] N12X#115W-[[#115-.625]*.15] M92 M1 N100M91 (ROUGH TURN) T0101S3000M13 X.65Z.005 G1X.2F.01 X-.065F.005 G0X.49Z.02 IF[#110LE1.]GOTO19 G1Z-[#110/2+.005]F.011 U.02 G0Z.02 G1X[.356+#510]F.015 Z-.03F.01 Z.02F.015 X[.228+#510] U.08Z-.02F.01 U.048Z-.062 (X.356) X[.356+#511]Z-[#114-.003]F.011 X[.4+#512]W-.022 X[.4+#513]Z-[#110/2] X.512F.015 Z-[#110+#113-.005]F.012 U.02 G0Z-[#110/2-.03] G1X[.4+#514]W-.025 GOTO20 N19G1Z-#110F.011 U.02 G0Z.02S#118 G1X[.356+#510]F.015 Z-.03F.01 Z.02F.015 X[.228+#510] U.08Z-.02F.01 U.048Z-.062 (X.356) X[.356+#511]Z-[#114-.003]F.011 X[.4+#512]W-.022 N20X[.4+#515]Z-[#110-.005]F.012 X[.468+#516] Z-[#110+#113-.005] X[.557+#517] U.068W-.0589 M92 M1 N800M91 (FINISH TURN) T0808S#120M13 X.34Z.02 G1Z0F.006 X-.035F.0035 G0X.24Z.01 G1X[.2538+#500]Z0F.002 G3U.0296Z-.0062R.021 G1U.018W-.009 G3U.0068W-.0044R.021 G1U.0327W-.0283 G3U.0051W-.0095R.019 (X.346) G1U#501Z-[#114-.0126] X[.3788+#502]W-.0164F.003 G3U.0112W-.0134R.019 (X.390) G1X[.39+#503]Z-[#110-.01]F.006 X.48S3000 W-.009 G1X[.42+#503] W.03F.008 U-.06W-.03F.002 U.06F.006 G0X.62W.02 Z-[#110+#113-.02] G1W-.019F.006 X[.49+#504]F.003 W.035 G0Z-[#110-.036] G1X.4F.015 X[.39+#503]W-.0107F.004 G3U-.0112W-.0134R.019F.002S3000 G1U-.0238W-.0119 G4U.02 X[.4031+#504]F.0035 G3U.0268W-.0056R.019F.002 G1U.0164W-.0082 G3U.0112W-.0134R.019 (X.4575) G1Z-[#110+#113]F.006 G4U.02 X[.5419+#505] G3U.0329W-.0095R.019F.003 G1U.0321W-.0278 G3U.0051W-.0095R.019 (X.612) G1Z-[#110+#112+.0048] G3U-.0112W-.0134R.019 G1U-.0286W-.0143 G97X.63F.01 G0Z.5S500 M91 M1 N1100M91 (THREAD ROLL) T1111S500M13 M26 X0Z.5 Z-[#114+.22] M25 G4U.9 M92 M1 N820M91 (RE-FACE) T0808S#120M13 X.33Z.02 G1Z.0005F.006 X-.035F.0035 M92 M1 N500 (5/64 IN. CROSS DRILL THREAD) IF[#123EQ0]GOTO62 M98P2102 M1 N62 (CROSS DRILL HEAD) IF[#124EQ0]GOTO65 M98P5101 (SUBPROGRAM) M1 N65IF[#121EQ0]GOTO900 N700M91 (CENTER DRILL) T0707S2400M13 X0Z.5 Z.03 G1Z.01F.01 Z-#109F.002 (ADJUST #109 TO MAINTAIN CHAMFER SIZE) M92 M1 N2700M91 (11/64 DRILL) T0727S1550M13 X0Z.5 Z0 G1Z-.094F.002 M92 M1 N2600M91 (#32 DRILL) T0626S2300M13 X0Z.5 Z-.075 G1Z-[#122+.035]F.002 M92 M1 N1000M91 (7/64 IN. DRILL) T1010S2440M13 X0Z.5 G65P9136K-[#121+.025]B.02F.0015W.3C.12Z-[#122+.035] M91 M1 N600M91 (BORE) T0606S3000M13 X.1255Z.5 Z-.04 G1Z-[#122+.002]F.002 U-.006W-.001 M92 M1 N900 (CUT-OFF) G65P9019X.67Z-#101F.002T909S500M3000E0 M30 % Edit: No cross drill sub for the one in the shank because I haven't had a stud requiring this hole yet since writing the program. It will get added, tho. |
| Need Help!- X3 CNC macros | trainfred | Syil Products | 6 | 05-20-2008 07:42 PM |
| Help with macros | afterburn25 | Haas Mills | 4 | 04-09-2007 08:19 AM |
| Macros | cncfreak | General CAM Discussion | 24 | 05-06-2005 05:04 PM |
| macros | toyoda | General CAM Discussion | 0 | 05-30-2004 04:56 AM |
| Macros | MachineSMM | General CAM Discussion | 2 | 06-20-2003 12:41 PM |
