Old 06-14-2008, 11:11 AM
ac123 is on a distinguished road
pattern repeat
hi, i dont uderstand how to program using pattern repeat on a LTC system 10T on fanuc controls. is there a simple way to understand it. thanks
Old 06-17-2008, 07:19 AM
dcoupar's Avatar
G73 is similar to G71 and G72 in that you define the finish shape in the subsequent blocks (ns to nf). While G71 roughs in a Z (turning) direction, G72 roughs in an X (facing direction), and G73 roughs by following the finish shape.
The manual says that it is used to rough premachined stock, or castings or forgings. I'm willing to bet that 95% of the programmers out there have never used it. IMHO, it's not an effective way to rough a casting.
Old 06-17-2008, 07:46 AM
chrisryn is on a distinguished road
95% of what I machine is castings I have never used G73. I use G71 and G70 all the time.
No matter how good you are, there is always someone better!!!
Old 06-17-2008, 11:39 AM
so how would you machine this angled groove with a turning tool, because in g70 and g71 it would rough it then on the final cut try to take out the angle groove in one big cut..
sorry for the poor drawinng
Old 06-17-2008, 11:44 AM
Me personally I would use a groove tool to rough it out then make a finish pass with a turn tool. Not real sure that I would use a canned cycle at all.
Old 06-17-2008, 11:53 PM
dcoupar's Avatar
I just might use a G71 "Type II" if I had the option. Or, I might give the old G73 a try, again, if I had the Type II option.
Old 06-22-2008, 12:23 AM
adamant is on a distinguished road
Attachment 61662
Use a G72 to rough it with a groove tool and then finnish it with the same tool using G1.
G72W.03P0(P is zero so you don't hit the wall)
G72P1Q2U0W0F.005 (U and W are zero because you are finishing with G1)
program repeat villiersterrace G-Code Programing 6 07-27-2010 07:55 PM
How Do I Repeat? TZ250 Dolphin CADCAM 2 03-04-2008 05:11 AM
program repeat heartlnd Haas Mills 3 08-19-2006 02:13 AM
Need help on G75.1 pattern repeat wayne mitchell G-Code Programing 1 03-16-2005 02:49 PM
