| G-Code Programing Discuss G-code programing and problems here! |
Hello. I have a leadwell LTC-15 with a Fanuc-OT controller. I have used G71 for roughing and G70 to finish in the past, and it has worked well. Now, I am trying to do the same thing, using G71 for Stock Removal in Turning. I enter all of my G-codes, and everytime it begins the cycle, it feeds down to the final cut of the rough ( .01 on Dia, and .005 on faces still remains ) immediately, instead of doing the usual Linear cut. Here is my Code : G01 Z0.1 X3.8 G71 U0.02 R0.1 G71 P1 Q2 U0.01 W0.005 F0.008 N1 G01 X1.15 G03 X1.25 Z-0.05 R0.05 G01 Z-.425 G02 X1.35 Z-.475 R0.05 G01 X2.90 G03 X3.0 Z-0.525 R0.05 N2 G01 Z-1.41 Thanks for the help, I hope I can figure this out... |
| Isn't there suposed to be a rapid move between the N1 line and the first feed? Like maybe: G01 Z0.1 X3.8 G71 U0.02 R0.1 G71 P1 Q2 U0.01 W0.005 F0.008 N1 G0 X1.15 G1 Z0 G03 X1.25 Z-0.05 R0.05 G01 Z-.425 G02 X1.35 Z-.475 R0.05 G01 X2.90 G03 X3.0 Z-0.525 R0.05 N2 G01 Z-1.41 It's been a couple of years so I may be way off. |
G00 Z0.1 X3.8 G71 U0.02 R0.1 G71 P1 Q2 U0.01 W0.005 F0.008 N1 G0X1.15 G01Z0 G03 X1.25 Z-0.05 R0.05 G01 Z-.425 G02 X1.35 Z-.475 R0.05 G01 X2.90 G03 X3.0 Z-0.525 R0.05 N2 G01 Z-1.41
__________________ The best way to learn is trial error. |
| It's my understanding that N2 should be an X move back to the starting X. It's never failed when I've done it that way. G01 Z0.1 X3.8 G71 U0.02 R0.1 G71 P1 Q2 U0.01 W0.005 F0.008 N1 G0 X1.15 G1 Z0 G03 X1.25 Z-0.05 R0.05 G01 Z-.425 G02 X1.35 Z-.475 R0.05 G01 X2.90 G03 X3.0 Z-0.525 R0.05 G01 Z-1.41 N2 G00 X3.8 |
| Here is how I would do it. G0 X3.8 Z.1 G71 U0.02 R0.1 G71 P1 Q2 U0.01 W0.005 F0.008 N1G0X1.15 G01Z0F.002 G03 X1.25 Z-0.05 R0.05 G01 Z-.425 G02 X1.35 Z-.475 R0.05 G01 X2.90 G03 X3.0 Z-0.525 R0.05 G1 Z-1.41 X3.8F.01 N2G0Z.1 G70P1Q2 Push the green button |
You do not need to finish the cycle with an X3.8 unless you want the shoulder to be smooth. I personally wouldn't use a G0 if you did want to. Using a G0Z.1 in the last block is redundant as the canned cycle will automatically rapid to X3.8Z.1 after it finishes. What are you machining that the DOCs are so small? |
| I realize that goz.1 in the qnline is redundant....... The onley reason I do it is because the guy that tought me on a Hardinge conquest T42 is because he said that not all can cycles on all machines act the same and it is best just to be safe? My guess is that that you have never seen a machine that did not retract in the can cycle? So do you always end your QNline with the stock diameter in x? Thanks adamant |
| iv worked on a ltc 15, im in work tomoro morning ive got all the g codes still. i think of the top of my head its on one line G71P10Q20U.01W.002D200F.004 Note D this is your depth of cut. then G70P10Q2O for finishing cut. ill check tomoro at work. |
As to ending the cycle at stock diameter...sometimes yes, sometimes no. Depends on where the cycle is ending. BTW, I was only trying to point out that the Z.1 was unnecessary (to the best of my knowledge), not trying to take a dig at you. Or anyone else for that matter. I try to keep my programs as clean as possible with no extraneous code. Naturally I ass-u-me that everyone else does also. Tain't necessarily true. Witness some programs with a G1 or G0 on almost every line. Now I suppose you are going to tell me that some lathes require it. You could be right. |
#11
| A single block G71 call is something else. |
| Type II G71 Stock Removal on Fanuc 0i-TB | lowehardware | G-Code Programing | 38 | 05-05-2008 08:50 PM |
| Type II G71 Stock Removal on Fanuc 0i-TB | lowehardware | G-Code Programing | 1 | 01-08-2008 05:55 PM |
| fast stock removal on steel | dynamotive | General Metalwork Discussion | 11 | 02-01-2007 09:02 PM |
| head stock and tail stock chucks | mocnc | DIY-CNC Router Table Machines | 3 | 10-19-2004 09:16 PM |
| Fanuc 0T Stock Removal Cycles | M@T | General CAM Discussion | 4 | 11-01-2003 06:43 PM |
