Old 06-04-2008, 03:08 PM
arch1 is on a distinguished road
5-axis programming question
what kind of 5-axis programming do you do? IE RTCP (rotation Tool center point) or is it Vectoring that uses IJK values
Old 06-05-2008, 02:51 AM
CNCRim's Avatar
huh?
Old 06-09-2008, 01:38 PM
Moderator
Dan B is on a distinguished road
If I understand correctly you are asking whether we program for full simultaneous 5-axis motion, or positional (3+2 axis), right?
In my case both.
Dan
Old 06-10-2008, 03:00 PM
Moderator
JerryFlyGuy is on a distinguished road
He's asking whether the programing has calculated the tool length in the code or do you have to let the control software compute the required tool position based on tool length offsets.
It depends on the software used to program the parts as well as the control pc driving the machine. Most of the OEM ones will do the offsets for you, most of the hobby level controls won't [Mach 3 for example, will not. EMC may, but needs custom programming to work]
HTH
J
JerryFlyGuy
The more I know... the more I realize I don't
T-Plus programming question?? Bobesmo Mazak, Mitsubishi, Mazatrol 3 09-27-2007 04:03 PM
Programming question g-codeguy Fanuc 4 06-05-2007 06:16 PM
4-axis, 3+2, or 4+ axis programming system? roboticist General CAM Discussion 0 09-04-2006 01:02 PM
4 axis programming question bkstout General CAM Discussion 3 03-30-2006 11:15 AM
Programming question AMCjeepCJ Milltronics 6 01-10-2006 09:58 AM
