Old 06-04-2008, 12:36 PM
ghostlx's Avatar
ghostlx is on a distinguished road
r plane commands
i have a problem and need some help.
i have a part to machine and i need to be able to draw the tool back 13.75 inches to clear boss i am machining around.
if i use g81 and set r to 13.75 it wants to feed from 13.75 to face of part to z depth how can i get around this so i can rapid to z.1 feed -2.0 rapid back to z13.75 and make my x&y move and then rapid to z.1 and drill to z-2.0 ect for 12 hole in a bc pattern so my spindel wont hit the side of the part. my machine is a toshiba horz, boring machine
thanks in adv
ghost
Old 06-04-2008, 12:59 PM
ChattaMan is on a distinguished road
G98
Rapid move to Z13.75, this is now your 'initial height'. Put G98 before your G81. This will make your tool return to the initial height before moving to the next hole. Thenit will move to next hole position and rapid down to the R plane. Your code should be.......
G0 Z13.75
G98 G81 X? Y? Z-2. R0.1 F?
X? Y?
next hole positions....
G80
Old 06-04-2008, 01:03 PM
ghostlx's Avatar
thank you very much
ghost
G2 and G3 Commands Bohemund G-Code Programing 19 05-28-2007 09:12 AM
Difference between BL and SV commands? Shizzlemah Fadal 3 03-23-2007 08:33 AM
EMC & the G28/G30 Home commands Javelin276 LinuxCNC (formerly EMC2) 1 07-18-2005 03:13 PM
construction plane and tool plane nervis1 Mastercam 9 11-04-2004 11:53 PM
cycles initial plane/retract plane HuFlungDung OneCNC 25 06-26-2003 07:02 PM
