Old 06-01-2008, 10:42 AM
REVCAM_Bob is on a distinguished road
macro's for probing?
Would anyone care to share probing macros for a fanuc 18i control, or similar?
Or maybe point to where they can be found?
Thanks!
Old 06-02-2008, 09:21 AM
psychomill is on a distinguished road
That's too broad of a question for probing macros. It depends on your probe make/model, machine, machine control, mill/lathe, mill/turn, variables used by machine builder, etc.
Are you adding a probe or looking for more subs on existing? Generally, going back to the builder is the best if you're missing them...
It's just a part..... cutter still goes round and round....
Old 06-09-2008, 08:17 PM
renitek is on a distinguished road
Actually, the probe is an accurate switch that send a on or off signal to CNC controller when the stylus was contacted (trigger) the component. There are two kinds of function that use measured both tool's length and diameter,which is put on the table of machine tool or set up a pull down arm beside spindle head in the lathe, is called tool setting and use measured the parts of features, which is set in spindle head or lathe's turret, is called inspection probe. For Fanuc or Meldas controller, all moving command is used G31 (skip function) when it received the signal from probe trigger. The machine was stopped moving immediately. For example: The parts of inspected program,
O3000
G90G80G40
POPEN
(Probing Cycle Start)
G55
G43Z30.H90F2000.(Edit Z coordinate in this block)
#31= #[2000 +#4111](Length of active tool)
(Two Touch Probing)
G31X0 Y0 Z-10.0 F2000.
G01X[0+#5061]Y[0+#5062]Z[0+#5063-#31]F2000.
G04P3
G31X0. Y0.Z-10.0 F30.
G01X[0.000-#502]Y[0.000-#503]Z-10.0 F2000.
#3004=0
(Output measured data)
#100=[#5061+#502]
#101=[#5062+#503]
#102=[#5063-#31+#501]
DPRNT[X#100[53]*Y#101[53]*Z#102[53]]
( End of touch move 1)
PCLOS
M30
Digitizing macro's pants Digitizing and Laser Digitizing 4 01-16-2009 02:07 PM
Macro's on Fanuc OT pinguS Fanuc 15 09-23-2006 04:51 PM
Macro's for the masses Equinox G-Code Programing 4 06-22-2006 01:47 AM
macro's Traceycnc300 Haas Mills 12 04-17-2006 12:43 PM
How to use Macro's smallplanes General CNC (Mill and Lathe) Control Software (NC) 5 10-10-2005 04:32 AM
