Old 05-26-2008, 02:23 AM
tturnbull50 is on a distinguished road
Machine freezing
When running a programme the machine freezes on a particular tool, after reset, it runs, after pallet change it drills one hole then freezes again, NO alarms. I have tried changing the tool No etc.. no luck. Particular part of prog is same for tap other than G84 depth etc. Can anyone help?
Thanks in advance.
Tom
Old 05-26-2008, 02:29 AM
dcoupar's Avatar
What machine? What control? Please post "snippet" of the program where it freezes.
Old 05-26-2008, 02:36 AM
Thanks for speedy reply
Daewoo, fanuc o-m control,
T100
M6 (TAPPING DRILL 1/4 BSP)
#1 =54
WHILE[#1 LE57 ]DO1 (No OF OFFSETS)
G90 G0 G#1 X0. Y0. S1500 M3
G43 Z100.H100 M8 T101
G83 G98 Z-24.R5.Q14.5.F300
G0 Z100.
#1 =#1+1
END1
freezes when it reaches g55 x0y0
Old 05-26-2008, 02:46 AM
dcoupar's Avatar
Is this code part of a macro, or part of the main program? To be honest, I've never tried running DO loops in the main. Have you tried coding it long hand to see if the problem's with the macro language or something else?
T100
G90 G0 G54 X0. Y0. S1500 M3
G55 X0. Y0.
G56 X0. Y0.
G57 X0. Y0.
G0 Z100.
Old 05-26-2008, 02:51 AM
Part of a much larger prog, the rest run fine but for some reason this one doesnt, mostly programmed offine via copy and paste, so loop works but on this one???? just wondered if there was a parameter wrong as I dont have book cant check it out.
Old 05-26-2008, 03:20 AM
Ciaran is on a distinguished road
Are you dripfeeding the large program? I had this problem before and eventually found that when the screensaver or monitor power managment flicked on on the computer feeding the machine the machine would freeze with the spindle still running.Problem is that it is always in and around the same place making you think there is a problem with your program.Try running just the part causing the problem.
Also could be sub routines as some contollers prefer long hand programs.
Hope this may help,
Cheers
Old 05-26-2008, 04:39 AM
ChattaMan is on a distinguished road
Decimal point
Look at your G83 block
You have two points in your number for Q
Old 05-26-2008, 08:08 AM
beege's Avatar
beege is on a distinguished road
And if that doesn't work after you fix that extra decimal point, try using #100 instead of #1
Old 05-26-2008, 04:01 PM
Red Frog is on a distinguished road
I can agree with you beege. I try to stay away from 10 as well.
LE ? Perhaps a "<>" could replace this?
Old 05-26-2008, 11:15 PM
dcoupar's Avatar
I don't believe "<>" is a valid Fanuc operator. Or... I could be mistaken.
Name:	Fanuc 0M Macro Operators.jpg‎
  #11   Ban this user!
Old 05-26-2008, 11:42 PM
WayneHill's Avatar
WayneHill is on a distinguished road
"<>" = not equal to. "NE"
Wayne Hill
www.codemangler.com
  #12   Ban this user!
Old 05-27-2008, 07:57 AM
AS9100 is on a distinguished road
Freezeing
Is it possible that you need to cancle the G54 Modal command before the machine will pick up the G55?/
madcam freezing skankpile MadCAM 8 03-21-2008 09:55 PM
freezing stepper Designsync Stepper Motors and Drives 6 12-31-2007 06:10 PM
freezing plate ilan General Metalwork Discussion 1 10-23-2007 10:32 AM
freezing plate ilan General Metalwork Discussion 0 10-23-2007 03:27 AM
freezing plate ilan General Metalwork Discussion 0 10-23-2007 03:16 AM
