Old 05-09-2008, 05:22 PM
CAMCRASH is on a distinguished road
Using GOTO in a mazak program
I am running a program being drip feed to a mazak control
machine is PH4800
the program is running standard eia G-code
is it possible to use a GOTO N " line number"
then have a N statement at each tool?
Will this allow me to jump to specific tool numbers in the drip feed program?
If so how would I format this statement for a mazak control?
Thanks for the help
Old 05-12-2008, 02:20 PM
psychomill is on a distinguished road
GOTO statements have the same format as a FANUC machine (and many others). However, if you're dripfeeding, you can't GOTO beyond what remains in the front memory or main memory buffer. Many controls will simply give you an alarm. There are some ways around this by using WHILE/DO loops or sub-programming for example. But drip feeding puts a lot of limitations to what you can or can't do for many controls...
What control model are you using? Some of this you can get around by using the memory card or USB instead of RS-232....
It's just a part..... cutter still goes round and round....
Old 02-21-2012, 01:00 PM
GTD222 is on a distinguished road
goto
What format does the GOTO command need to be entered, my keeps adding zeros after each letter
Old 02-22-2012, 07:48 AM
fordav11's Avatar
fordav11 is on a distinguished road
GOTO is part of Fanuc macro.
Mazak EIA mode is not the best implementation of a G-code interpreter.
I seriously doubt it will understand any macro commands.
The fact that your control adds zeros after the letters means it does not accept GOTO..... because it does not understand or have Fanuc macro capabilities.
Old 02-24-2012, 10:29 PM
I'm not sure what "Ford" is getting at here but....
Mazak running EIA has no issues with macros as it is done all over the world.
Curious about what you mean by "control adds zeroes...." and what control are you using?
Old 03-01-2012, 05:26 PM
dpuch is on a distinguished road
I agree with everything psychomill said.
We have a mazak with a nexus control and eia runs just like on a fanuc control. Older Mazak controls might not be as compatible.
For me
Code:
GOTO 20
N0020
works just fine.
Old 03-02-2012, 02:13 AM
fordav11's Avatar
it doesn't work on older Mazak controls like T2/T32/T Plus etc. that's what I was talking about
Old 03-02-2012, 10:09 PM
gotta be clear Ford.... .... you're going back a few generations of controls there....
can't speak for T2, 32 or Plus .... Too many years ago and I can't remember....
However on M32 or Plus..... No problem! (can't remember M2 or older anymore...)
GDT222 doesn't say what machine or control is being used here.... So I still don't get the "adding zeroes" thing....
Old 03-16-2012, 05:31 AM
psaudio is on a distinguished road
we use GOTO all the time on our T + machines
Mazak M2 Sample program EIA zabba Mazak, Mitsubishi, Mazatrol 13 05-01-2008 06:23 AM
Need Help!- Simple loop program for mazak katsbobo Mazak, Mitsubishi, Mazatrol 3 04-07-2008 06:11 PM
Need Help!- GOTO Z monte55 Mach Software (ArtSoft software) 12 02-06-2008 09:03 AM
iso program within mazatrol (mazak VTC200C) Bodie Mazak, Mitsubishi, Mazatrol 2 09-07-2006 06:38 PM
Mazak Program Rotation Code? Cascade Dave Mazak, Mitsubishi, Mazatrol 3 04-27-2006 02:22 PM
