Old 05-09-2008, 12:01 PM
slkret is on a distinguished road
G code help C-X axis
Hello to everyone. I'm a new poster and need some G code help. I am a wood gear clock builder who is tired of hand cutting gears. I'm exploring the possibility of adding CNC to my old Rockwell mill. the problem that I have is that the Y axis travel is too small for the gear sizes I want to cut. One solution is to use a rotary axis (C) along with my X axis to cut the gear tooth profile. I'll be using either Turbocnc or Mach2mill to drive my controller. I will be cutting epicyclic gear profiles. With wood gear clocks that profile is often approximated as a circular arc segment. I have written g code using g2 and g3 for cutting using the X and Y axes and the code looks good in a simulation. I need to do the same thing now using the C and X axis and am not sure how to set this up.......Help me please.
Steve
Old 05-10-2008, 08:53 AM
ProProcess is on a distinguished road
Don't know a thing about the controllers you mentioned.
The method you are looking for is "Milling Interpolation" which translated the Catresian XY system to Polor Coordinates.
You would implement the Milling Interpolation G-Code then use the G2/G3 X/Y code you've already simulated, the control would translate to X/C moves to generate programmed profile.
Good luck!
Need g-code for 4 axis semi-spheres. jaru-eri Mach Software (ArtSoft software) 17 04-29-2008 08:49 PM
zero axis key code? drafterman Mach Software (ArtSoft software) 2 03-06-2008 08:18 AM
4 Axis CNC - MS Excel Source code (VBA) arman Visual Basic 2 02-06-2007 04:27 AM
Z-Axis Arc G-Code? GTmike400 G-Code Programing 16 01-27-2006 11:15 AM
using bobcad to create c axis g code? stuart76 BobCad-Cam 0 08-15-2005 05:06 AM
