| G-Code Programing Discuss G-code programing and problems here! |
I need help in generating the G-code to machine a gear like the one in the picture below. the total diameter of the gear is 1.375", the root gear is 1.295" there are 72 teeth cut like a "V" and the length of each line that makes up the "V" is .050". I'm not very knowledgeable in CAD programs, and wondering if a CNC vertical Machine center could be used to cut the gear , and what type of end mill would i need to cut the "V's" in the gear??? Thanks in advance for any help. ![]() |
| Hi: If the profile of the V has to have a 0 radius, then you would be better off using a form cutter, or a gound single flute cutter with the included angle of the V, with the blank setup on a rotary table. The VMC would make a number of passes to get to final depth, and then the gear would be indexed 1/72 of 360 (manual indexer would be fine). If you lie the gear flat on the table, and machine the profile of all the teeth with a small cutter, you may end up with a tapered profile, and a radius in the V. just some thoughts regards regards
__________________ ---------------- Can't Fix Stupid |
| If the CNC is a 4 axis or at least setup with an indexer then yes. If you insist on milling it as a profile then you have to answer the question of how big a radius you can have in the bottom of the V grove. If you can have a 0.010" rad then you can use a 0.020" diameter end mill, Harvey Tool catalog has some 0.020 dia. end mills with a 0.060 DOC and a 0.170 reach, you will need something in the range of 50,000 RPM or better to use them. Edit: The other option (and likely the one used to produce these ratchets) is and rotary broach in which case you just need a Z move. |
| Basic Bevel Gear - Milling a valley for gear teeth | ngr1 | General CAM Discussion | 10 | 04-05-2012 09:55 AM |
| Diameter, Pitch, Number of Teeth, etc. on Spur gear? | SlimJimmy | CNC Plasma and Waterjet Machines | 15 | 12-03-2008 10:10 PM |
| Need Help!- Cut body, teeth | weirdharold | Mastercam | 5 | 03-28-2008 08:18 AM |
| Sprocket teeth | MattMachinist | General Metalwork Discussion | 0 | 04-17-2006 09:06 PM |
| Gear Teeth thickness problem. | nikolatesla20 | Mechanical Calculations/Engineering Design | 3 | 08-09-2005 01:39 PM |
