| G-Code Programing Discuss G-code programing and problems here! |
| Start the tool at the bottom about 1 or 2 threads past the bore. Lead into the Pitch Diameter and call your cutter compensation so you can adjust the PD. Helically CCW Interpolate two passes up. Cancel your tool compensation then move to the next bore. ex. Using tool centerline single hob thread mill with a diameter of .65D N3 T3M6 G90G54G40G0X2.04Y-1.875S7000M3 G43Z1.H3 Z.1M8 G1Z-.6F50. G41G1D3Y-2.331F20. G3X2.04Y-2.331Z-.5167J.456 X2.04Y-2.331Z-.443J.456 G40G1Y-1.875F50. G80G0Z.1M9 Z1.M5 G91G30Z0M19 M1
| Thanks that looks like what I came up with. I am using a Haas tool room mill so a pipe tap stalls my spindle + I have over 200 holes to tap in hastaloy I have tried the hob mills they do great for 2 or 3 parts but don't hold up well and at 150. a pop not cost effective. I have have good luck thread mill std threads in the past so hopefully this will work. Thanks for the replies Dadeslot |
Try Harvey Tool fair prices for micro grain carbide thread mills.
seco tools offers thread mills that will suit your application. they are a bit pricey but they work great.we thread mill heat treated inconel 718 all day long, no problems.also if you go on their website they offer a downloadable interactive program called "thread milling wizzard" .just answer questions as you go along and it will give the g-code for any threading application.hope this helps |
How thick is the work piece ? If it's less than an inch, use a high spiral cobalt tap. Also use a thicker mix of coolant, or tap heavy. Use a rigid taping method as well. It's all what works. Threadmills are great time savers. I always use them on larger threaded holes. They are great for blind holes. When all else fails, use a tap and heavy lube. You probable knew this all ready. But, I never know who I'm talking to. Brginner or otherwise. Good luck |
#10
| Vardex has great coated threadmills as well. They also have a free program (download) to generate the threadmill code. Much easier to use than Seco's and isn't a massive download.
| thread milling | fourperf | Fadal | 13 | 03-10-2008 07:14 PM |
| Thread Milling | ragman | General Metalwork Discussion | 2 | 02-04-2008 09:04 PM |
| Thread milling | TT350 | Tormach PCNC | 7 | 11-30-2007 09:01 PM |
| thread milling | fourperf | Fadal | 2 | 11-20-2007 09:32 PM |
