Old 04-17-2008, 10:50 PM
Monte is on a distinguished road
Program g-code for mill as multiple tool lathe?
I've seen a few video's of cnc mills being used as a multiple tool lathe with the tools mounted to the mill table and the part chucked in the spindle. How do you program for this sort of setup?
Monte
Old 04-18-2008, 06:51 AM
Andre' B is on a distinguished road
MS Word
Old 04-18-2008, 09:30 AM
Cool
Originally Posted by Andre' B View Post
MS Word
Would OpenOffice work as well? I don't have MS Word.
Monte
Old 04-18-2008, 10:06 AM
ger21's Avatar
I think he means any text editor, as you'll be coding it by hand.
Old 04-18-2008, 10:15 AM
yeah, I figured that out.
Monte
Old 04-18-2008, 12:46 PM
Yep, basically anything that can save in plain text.
I would be surprised to find CAM software that would handle that type of thing without a good deal a manual intervention.
If the CAD/CAM software has a good macro language and you wanted to take the time to set it up you probably automate a lot of it.
Old 04-18-2008, 02:38 PM
ger21's Avatar
You could probably use a .dxf to g-code converter and carefully draw the "toolpaths" and then convert away.
Old 04-18-2008, 08:02 PM
cam1 is on a distinguished road
I'd want to make sure that the parts are chucked pretty short, and the tool set high off the table to avoid a crash.
IMO mills are for milling and lathes are for turning. (I'm not talking about specialized turn/mill machines)
Short of turning a few shoulders on some round stock, what's the motivation?
regards
Can't Fix Stupid
Old 04-18-2008, 09:44 PM
All good points.
regards
Uhh, I have a cnc mill and no lathe.
Monte
Old 04-18-2008, 09:54 PM
Kevin Taylor is on a distinguished road
Lathe/Mill
Take a look at BTC clubhouse I posted pic's a while back of my rendition If you put the tool on the corect side of the vice or part your program will convert into Lathe as long as you can cut in radias diminson on the lathe I have since got a lathe to do the part's and will do so I would agree with the short part and close chucking don't spin anything you can't duck The bird nest is a proublem and likes to throw coolant but shure beat's turning part's by hand Good luck Kevin
  #11   Ban this user!
Old 04-18-2008, 10:00 PM
Thanks. I'll try to find it, but if I don't, what's the BTC Clubhouse?
Monte
  #12   Ban this user!
Old 04-18-2008, 10:26 PM
BTC Clubhouse
Look in the hardinge Bridgeport fourm or in today's post's It will be back a few pages Good luck Kevin
Which do you find more difficult to program? Lathe or Mill? fordbroncoxlt General Metalwork Discussion 13 05-20-2009 05:00 AM
Taig Mill converted to a gang tool lathe... Anokiernan Taig Mills & Lathes 5 02-16-2008 04:10 PM
Tl-25 multiple offsets for same tool Help mkmk123 Haas Lathes 1 11-23-2007 06:22 PM
Inexpensive Wireless Intranet Based Program Transfer to Multiple Machines ChopperDoc General CNC (Mill and Lathe) Control Software (NC) 0 05-21-2006 12:36 AM
How to cut multiple parts (loop a program) Bird_E Mach Software (ArtSoft software) 6 05-13-2005 03:16 PM
