Old 08-18-2004, 07:59 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Gcode help
What would be the Gcode to move an axis 100mm in a positive direction from where ever it is. I dont mean a Gcode telling the axis to go to a set spot like "G0z100" I mean a code that will say move 100 from where ever you are now. Is this possible?
Old 08-18-2004, 08:27 AM
rmtucker is on a distinguished road
Try
G91 G0 Z100
G90
This just tells the machine to make an incremental move (g91).
Dont forget to switch back to absolute (g90)
Mark
http://www.weardalecnccarving.co.uk
Old 08-18-2004, 08:39 AM
ynneb's Avatar
Moderator
Thanks 4 that.
Old 08-21-2004, 02:01 PM
tex tex is offline
tex is on a distinguished road
U and W commands (incremental) could be useful. For example:
G00 U-1.8 W-3.1
means that the tool should move -1.8 along the X axis and -3.1 along the Z axis (inches or mm) from the point where the tool was before the execution of the command.
Old 08-21-2004, 04:16 PM
ger21's Avatar
I don't think Mach2 supports this, though.
Old 08-23-2004, 12:54 AM
tex tex is offline
Sorry, I really had no idea...
Old 08-23-2004, 12:59 AM
ynneb's Avatar
Moderator
Hey Tex, I guess I should have mentioned Mach2 in the question.
I think Ger must have already known thats what I use.
Thanks for your contribution though.
Old 08-23-2004, 01:03 AM
tex tex is offline
It's OK....you're welcome...
Old 01-30-2005, 12:13 AM
mold tech is on a distinguished road
I was wondering if someone cold give me a list of g codes that will work on a bandt I control and tell me how to set the fixture offsets, i am familiar with coversational programming but not g code any help would be greatly appreciated
Autocad to gcode JamesMI Autodesk Software (Autocad, Inventor etc) 17 12-02-2011 03:54 AM
Is it possible to get a gcode into Rhino MrBean Rhino 3D 11 04-03-2005 08:41 AM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 07:51 PM
dxf to gcode problem... freezer General CAM Discussion 9 02-19-2004 01:02 AM
Gcode verify autocad plugin balsaman General CAM Discussion 1 10-31-2003 12:22 PM
