Old 04-16-2008, 12:22 PM
protrxrptr17 is on a distinguished road
Can't reverse spindle
I'm trying to cut 1-1/8- 12 left hand thread. The spindle tries to startup in the forward direction and kinda makes a strange sound. The machine goes into alarm mode and I have to cut the power off to make it restart. i make the spindle run in reverse manually just fine. This is the first time I have tried to run in reverse. It's a 6T control. Any ideas?
Old 04-16-2008, 02:05 PM
JDenyer232 is on a distinguished road
Post your code and the alarm that you received, this might shed a little more light on your problem.
Old 04-18-2008, 01:26 PM
I got it to work by commanding M03 then M05 then M04.
Spindle Reverse on a Bridgeport Interact? UKRobotics Bridgeport and Hardinge Mills 29 10-27-2007 08:04 AM
Spindle Forward/Reverse = High/Low change AdyAstley Machines running Mach Software 2 06-06-2007 09:33 PM
reverse spindle problem bala955 Fanuc 1 03-08-2007 05:24 PM
Spindle sticking in reverse creep_pea Bridgeport and Hardinge Mills 3 10-02-2006 10:48 AM
Reverse CNC adwsystems General CAM Discussion 4 05-16-2006 07:05 AM
