Old 03-07-2008, 06:12 AM
stirling is on a distinguished road
what's this mean please?
Hi - I've a friend with a Trend router and we tried to run some of his (engraving) gcode on my Mach3 setup. It (Mach) kicked up at every Z axis move which all looked like "G1 Z-9 2"
The intention from what he programed in the CAD/CAM was to lower the Z to -9 so what's the <space>2 for? I've read through the NIST doc and can't see anywhere where a G1 takes a param like this.
When we took all the <space>2's out of the code and just left G1 Z-9 then Mach ran it fine. (all in mm by the way - it'd be some engraving 9 inches deep wouldn't it )
Ian
Old 03-07-2008, 09:13 AM
mactec54 is on a distinguished road
Hi stirling
May be something is wrong with the posting of the code or it could be missing
a letter in there like G1Z-9F2. F being the feed that the Z axes would move at
The Zaxes can have a different feed rate than the X&Y axes when you use it like
this
Mactec54
Old 03-07-2008, 10:34 AM
Hi Mactec - thanks for your reply.
Good point - mind it did work fine on the Trend machine. Maybe on a Trend the F for the Z is implicit. Come to think of it the gcode didn't have any XY feed mentioned at all. Maybe that's just set on the controller. The first line was also a comment but with no parentheses or anything so it's looking like Trend have a little variation in the gcode dialect just for them.
Anyone have a Trend?
Ian
