Old 07-26-2004, 05:38 PM
CADkathy is on a distinguished road
Unhappy G-Code letters What are the definitions?
I am currently setting up a machine and having problems. I am looking at the G-code after posting, how do I find the definitions of each of the letter codes? Example what is SP,SF and PA? Is there a place to find these definitions?
Old 07-26-2004, 06:03 PM
Gold Member
HillBilly is on a distinguished road
SP,SF and PA could be your problem. Most G code programming is one letter followed by a numeric value.
Example:
N010 M03 S300
N010=block number
M03=spindle forward misc. function
S300=spindle speed of 300
Darek
Old 07-26-2004, 06:04 PM
DR-Motion's Avatar
DR-Motion is on a distinguished road
Hi CADkathy,
here is a link to general G-code definitions... http://www.linuxcnc.org/handbook/gcode/g-code.html
As I understand it, SP,Sf or PA are NOT standard RS274D G-code.
Hope this helps... a bit
Gary
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 07-26-2004, 08:06 PM
TAB TAB is offline
TAB is on a distinguished road
It might help to identify what control you are using. Some of the PC based or other controls may have unique designations.
Old 07-29-2004, 07:39 PM
matrixman is on a distinguished road
What is your CAD program? What is your machine control? If you have a programming manual for the machine, it will tell you all you need to know. Otherwise give some more info here and you'll get the help you need.
Matrixman
Old 07-30-2004, 02:50 PM
GrahamIT's Avatar
GrahamIT is on a distinguished road
Ultimate G-CODE Reference
Complete G-Code reference from the people that had a bit of a hand in designing it. NIST...
Old 07-31-2004, 10:57 AM
Talking Thanks for the Leads!
With the information y'all (Yes it has been a long time since I moved South) sent, I was able to contact my software provider and determine the post processor the machine manufacturer suggested I use was incorrect. I am now using another post and my machine is cruising.
Thanks again!
Old 08-04-2004, 07:37 PM
c-c-cncboy is on a distinguished road
Kathy,
Just for the record, SP and SF and PA represent "Select Pen" / "Set Force" / "Plot Absolute" in Hewlett-Packard's proprietary 2D pen-plotter language HP-GL. They are adopted also into certain versions of RML and CAMM-GL used with Roland 3D micro-mills.
Regards, Terrence
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 10:21 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 03:58 PM
Autocad fonts (letters) to .dxf files fiedd General CNC (Mill and Lathe) Control Software (NC) 15 02-08-2005 06:54 PM
I need sample G code program bunalmis G-Code Programing 1 08-24-2004 04:50 AM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-02-2003 12:08 AM
